QLD CHRISTMAS CRUISE AND DINNER
Replace Front RH park light Corolla 2006
Hi, I am new to this forum and i hope i can get some help. The mechanic said he can't tell me how it's done. I will keep this in mind before i take a car there again. Interestingly, the manual only refers to the front LH side Replacement of the Front RH park light Corolla 2006, but not the RH side. Could anyone alight me on this? Thank you. -
5
Oil leak help!
Did anyone figure this out, my stivo is doing same thing. -
Oil Leak
Hello, may i request of your idea what kind of issue im having with 2017 Fortuner, some oil leak as per attached photos, any one experience this thing before? Thank you in advance for your answers -
Aftermarket Air Intake
The camry/aurion NA ones fit fine with the TRD. The throttlebody is the same diameter etc. The main issue with them is the breather pipes are setup differently but that's not a big deal. I've not seen one designed specifically for the TRD(There are lotus ones but the engine is orientated differently). Some of the intakes designed for the NA version are as follows: -K&N: 69-8611TS -AEM: AEM 21-870C -AF Dynamic: 0715-TV-HS -HPS Shortram: 827-534 I designed and printed a MAF pipe and filter enclosure with an attachment to goto the stock air intake locations but never got around to create the pipe that connects the two together, If you have the ability to print in a high temp resistant material I can probably share my files. I personally use the AEM intake and it works and sounds well. -
Head Unit with Apple CarPlay
Did you end up getting a head unit for the Rav4? I'm thinking of purchasing one from eBay for my 2015 Rav4. -
RZN169 Poor fuel economy and low/rough idle at cold start up
Hi all, First time writter. Long term reader. I have a RZN169r 1999 Toyota Hilux 3rzfe Manual 4WD with 425,000KM. Which we have owned from 130,000KM. Since about the 400,000km mark (it had a new/used 138,000km engine only, installed at 385,000KMs) it has been using fuel and idiling rough. I'm getting 100kms less then usual. We would normally get 450-550kms per tank. Now getting 350km-400kms. Our long term mechanic of 20 years retired a few years ago and I have no one in my local area who knows these engines or who I trust. Any sugestions on who I can take my car to? I also have no faith in my local Toyota Dealer. I'm in Sydney NSW. Thank you in advance. -
Any RA 60 owners?
Hi all ,new member here. Just wanted to introduced myself and show off my new to me 1983 Celica 2.0 XT liftback. Got from the original lady owner who had it for 41 years! It's had 2 sets of seat covers on the front seats and when I removed them the seats are like new. I'm over the moon with it. I'm southside of Brisbane if anyone is local...... -
Bluetooth stopped working
My 2008 Toyota landcruiser 200 series head unit's bluetooth has stopped connecting to phones, has this happened to anyone else and if so, how do i fix it? Thanks -
Purchasing 2014 Prado GXL - Requesting Inputs
Hello, Thanks for reading my post. We're in the middle of the process of buying 2014 Prado GXL from a private buyer in Brisbane. It has 107K km on the odometer, we arranged an independent inspection and only noticeable issue came out of the inspection is presence of rust. Inspector said general wear (ageing) and rust to the components consistent with the age and mileage. I've attached some of the images(related to rust) from the inspection, please review and let me know if I should be concerned about any future issues or as the inspector mentioned is the rust presence is expected for a 10-year old Prado. Appreciate your help in advance. Thanks, VM -
3rd Gen (XU50) Kluger new aftermarket radio install
Update, yes it does retain the reversing guide
