Camcon VVTi-L Controller
The car is going great now and it was a mechanic called Adam at Brutton Automotive Windsor NSW. I am so impressed with the customer service from this young man, he has gone above and beyond in the times I have taken my vehicle to him.- 1
Hi l have a 2000 vx Prado and the small cylinder on the right of the master cylinder is making a churping noise. It occurs randomly but is most prevalent when brakes are applied. The pipes going to the offending area vibrate when noise is on. Is there a remedy. -
I have concluded that there is water leaking into one or more cylinders due to a failing head gasket. It most likely is original and has done well to last for 32 years. Composite gasket. I plan to pull it apart and have the head checked and machined in the usual way, and change the timing belt and water pump etc. while I am at it. I'll mark the thread as solved. Jim. -
Tyre tread damage
Thanks for the suggestion. Just came back from another shop this arvo. It feels much better now.🙂 -
Ever get this figured out? Mines just started having the same issue -
Changed my mind again, (last time 😁) Method Race Wheels 703-HD Bead Grip Matte Black 18x9 6x139.5 +40ET ZMR70389060540H, Micky Thompson BAJA BOSS A/T 275/70/R18 33.2 inch and largest legal size with the 2 inch lift. 1.6 inch larger than standard. Cheers JA -
OBD port lock for 300 series
Latest news suggest that car thieves are now using the OBD port to steal 300 series. Has anyone found a decent OBD port lock that works with the embedded OBD port in 300 series? -
Hey all! Recently upgraded from a 2009 Kluger Grande to a 2017 Kluger GXL... the 2009 was decked out with a round chrome nudge bar and all, making it easy to mount a UHF antenna up front! But, this newer model I have gone with the OEM Toyota nudge bar that I really like the sleeker look of, but it does not give me anywhere to mount a UHF antenna, and even more so, I cannot seem to find any bonnet hinge mounts for this year model available online! Not really wanting to go with any thoughts or suggestions greatly appreciated! Cheers! -
Tyre tread damage
Hi, My take is that your alignment is way off, despite what the tyre guy says. Find another shop, or go to a Toyota dealer. I had this happen, years ago, with my little Honda Scamp. Tyre guy set the toe to his "standard" 3 deg toe in. The car was a front wheel drive, spec was toe out 3deg, and yes, the tyres wore very quickyl. Herb -
Prado veggie oil
Correction: The power for the pump comes from the engine ignition 12v distribution in the engine bay fuse box. I will take a photo of it tomorrow and post it here in case anyone else wants to use +12V with Ign ON. Tony
