Jeffys - 2003 Camry Altise - Updated pics !!
jeffy
2003 ACV36 Camry Altise 5spd
370xxx Kms on Chassis
Exterior
  • 18" TRD Kappas for dailys
  • 17" Se37k for track
  • "M3" Type Spoiler
  • Rear Visor
  • Facelift Sportivo Grille
  • Rear De-badged, Black Toyota Emblem
  • Blacked out chrome window sills
  • Rear guards rolled
  • Weather Shields
  • 3000k Foggies
  • LED License Plates & Reverse Lights
  • Tinted
  • Custom Personalized Plates
Interior/I.C.E
  • Celica zzt231 Steering wheel
  • Black interior from facelift sportivo
  • TWM Short shifter with solid mounts
  • Razo RA25 340g weighted gearknob
  • Black Ceiling/Side Interior Bits
  • Junction Produce VIP Black Fusa Knot
  • JDM Cup holder
  • Map light from sportivo
  • Red LED Dome light
  • Broadway Mirror
  • Fire Extinguisher
  • JVC XR-616 double-din head unit
  • 6x9 Pioneer Speakers w/ 500w amp
Suspension/Handling
  • Fortune Auto 500 Series Custom Camber Top/Rear hats with 12/12 Spring Rates
  • Whiteline front Strut Bar
  • Whiteline 23mm Rear Sway bar with endlinks and polyurethane bushes
  • Superpro Polyurethane Bushes for front rear/inner front lower control arms
  • Aurion Front rotors and calipers
  • DBA T3 slotted 4000 Series  - Max High Carbon rotors
  • Rear Slotted Rotors
  • ADR Approved Brakeswest Braided brake lines
  • Remsa Daily Pads
  • QFM A1rm Track Pads
Engine
  • 2AZFE 2.4L 4cyl 310xxx kms - piston oil rings fried - blowing some smoke - needs rebuild
  • Dynoed 98.7fwkw at Nugget Nats 2018
  • Carbon Fibre Engine Cover
  • TRD Oil Cap
  • Hella Twin Horns
  • Sticker-bombed cruise  control and fuse  box
  • Carbon fibre short ram intake with cold air feed
  • Red Radiator Hoses
  • 2-core Alloy Radiator from mx83 cressida
  • Aluminum overflow bottle
  • Slimline highspeed cooling fans
  • Weapon R Headers
  • 2.5" Mandrel Bend exhaust with cat
  • Magnaflow muffler with 3.5" Twin tips
TO DO/Fix list !
facelift sportivo front bar/ side skirts  and TRD Accessories rear lip
rear demister
diver side power window mechanism
subs/brackets/boot floor
semi wiretuck/neaten up engine bay [braided wire sleevings]
paint rear console/3rd brake light/ohjesushandles  black
black projector headlights/ foglights
turbo / custom shifter
os giken lsd/lightened flywheel
engine rebuild tings - cams/rods/pistons/valves/springs/retainers
arp head studs
Wishlist
Toyota Premium Horns
Alloy Sports pedals (celica  ZR/is200/camry sportivo manual)
LED Signal Mirrors from Aurion
TRD Front/Rear Brake Setup
This is my journey and story of this car from when i got my Ls, to getting into my P's and until now... still have a little bit to do,
"the car is almost done" -saidnocarguyever
Thanks for looking !
-Jeffy
Updated modlist 15/10/2018 - pics to come !
- black painted grille, and black plasti dipped front badge
- 8000k low beam HIDs 5000K Low beams
- 8000k 3000k high beam HIDs
- JVC XR-616 double-din head unit
- debadged rear, black toyota emblem
- custom plates
- led license plate lights and parkers
- red led dome light interior
- camry badge inside
- Plasti dipped in black Atlas Toyota Rims
- pirelli P7s 205/65/15
- 6x9 pioneer speakers with a 250w amp.
- poly uretahne bushes
- hella twin horns
- Custom Projector Headlights
- TWM Short Shifter with solid mounts
- Razo RA25 340g weighted gearknob
- SSR Professor SP1s 18" Gunmetal Chrome.
- 18" TRD Kappas
Future mods;
-white line rear sway bar
-ultra racing front lower bar -
-ultra racing front sway bar
-Front Sway Bar
-Rear Sway Bar Links
-UR Rear Lower Bar
-Bigger Brakes - (considering getting the 4pot kluger brakes with 328mm rotors)
-cai (maybe)
-sportivo muffler tip or whole exhaust system/headers
-black/red interior trim 15/06/2013
-tinted rear tail lights
-coilovers - BC Type Coilovers Upgrading to some Fortune autos with stiffer spring rates
-weathershields-darker tint
-Advan AVS T6's ACHEIVEDDDDD !~!!!!! 17x8 +30 !
-led footwell
-a spoiler perhaps ? - yess an M3 type spoiler
-paint callipers
-2x 12"Subs ! (in progress)
-custom boot for subs
-led boot lighting
-plastidip the chrome bit on window seal
-Vizage Lip kit ordered as of 17/10/2012
- Foglights
- Manuel Tranny  11/04/2013
Most standard excesses are $500 and most companies will charge you extra on top of your standard excess due to your sex and age. Toyota's seem a little higher than normal (AAMI from memory charge $750 on top for males 18-20). It will be listed somewhere on your insurance papers.
An increase in your premium as a result of your accident comes as no surprise.
Bad luck mate. As Andrew said the excess is there with all insurance companies. Just need to find one that is cheap enough in terms of premiums and least amount of excess. However once you mod the car be prepared for heftier premiums as they know not a lot of options is out there for you. Gotta pay to play :).
Shannons is good if you are above 25 and have a nice driving record. Paying 900 a year and 500 excess with lots of major mods.
^ lol
so i have to tell insurance about lowering? and it will definitely go up in price? <_<
Yes, you must tell your insurer about lowering your car. Even if you install a new strut brace/sway bar/alloys etc.
As for a premium increase, it depends on your insurer. When AAMI switched to a more mod-friendly attitude, they gave the first 3 mods for free before your premiums went up.
I didn't pay extra when declaring my extractors, catback and lowering springs.
^ lol
hrmmm.. does that mean i have to tell toyota about the 3 bar upgrades that i did :S ?
my insurance doesnt know ***** about my new wheels lol.do they really need to? :blink:
Are these serious questions?
well for my one yeah.. kinda, but then again my panel beater told me to change insurance after the camry gets fixed,
Your premiums will be higher with other companies due to your accident (I'm assuming you are at fault given you are paying the excess).
You will still need to declare mods to your new insurer regardless.
I'm with Shannons and for the first 2yrs with them was paying $770 with all my mods listed and $500 excess,but after my hail claim they put the price upto $900,so i'm hoping it will come down a little next year :unsure:
and yes to being honest with your insurer,list all your mods with them,the piece of mind knowing your covered is worth the extra dosh.
also remember to read what % they will pay back on your modifications,you can up the amount for a price of course,i currently have $18000 worth of mods listed but they will only pay about 60% of that if something happens..ie audio worth $10,000 will only pay $6000 unless i decide to pay more per year.
Wait wasn't your car red ? Or is it just really dirty. Can't tell on my phone lmao
heh, yeahh very very dirty, :P its at the panel beaters atm, so yeah free car wash :D
dudeee, must get some wheels and slam her asap!
Yeahh, i have been thinkin along the 5/6 spoke range, leaning towards the last photo more :P
Those last ones would look really good on a lowered Gen5.
mmm agreed,
was thinking gun meta grey or gun metal black, or powdercoated charcoal,
my friend has a similar wheel like that for sale
dtm rushs
18x9.5 +22
would look good!
i dont think 9.5 would fit, ill try to fit in 18s, and roll guards and stuff, ;)
      Rukus for sale
      For Sale: Toyota AE86
    4. 83
    5. 26
    6. 2
    7. 2
      Head Unit with Apple CarPlay
    8. 3
    9. 1
      Invisible Instruments fix
