Put the new sway bar in. Drove the car for a bit handled like awesome sauce and then the engine popped. New record: 7 weeks.
Today I fitted the Whiteline rear sway bar, and man what a difference it makes! car handles really well now even with it being a touch too low and with rubbish tyres on. best mod, really happy with it and recommend it for any FWD car :D
All was great until i was finishing up my test drive and blew my head gasket again on the way back.... ripped the head off it and here is the damage:
It holds a new record: its been on the road for about 7 weeks which beats last time :P haha
Car will be returning to track spec as im Thinking of going to a test and tune on friday april 13 (ooh scary!! Lol)
Pretty sure it Will be my only opportunity to track this thing till september as queens bday is right in the middle of my exams :(
Long list of things to do by then (including putting the motor back together :P )
good luck with everything, your sway bar seems to look like 20mm
Thanks Ben :) Its an 18mm sway bar, but apparently it feels like 22 on the stiffest setting and 18 on the softest.. so yeah its "20mm" at the moment ;)
Fitted the head back on last night with the TRD gasket, torqued it and put the timing belt on after much frustration. Tonight ill put the cam covers on, the dizzy in with a new o-ring (no more leaks :D ) and connect all the electrics to get it all running again.
Then skidz? :D
Well today has been hairy. Car ia running damn well aftera few close calls with a problem with the timing belt and very close to a fire caused by leaking fuel out of the injectors.
But as i said before thr car is running damn well just how a 4age should!! :D
for yr sway bar, 18 to 20 is the best...
leaking fuel? why, that is not good.....how come u got so many problems?
Ben, the head has come off meaning injectors out.. all it takes is a slight split in an injector o-ring and as the fuel is pressurised, it will weep or leak... credit to Justin for working on his own car ... it's not a new car!!
Posted (edited)
Ive got it on 20 now, and it feels really balanced. Its still slightly inclined to understeer but ill see how it goes after i raise it and get an alignment.
Thanks Mick and youre exactly right! Yeah, this car has been the only unreliable car ive had so far, but its also the oldest. Plus being a daily puts extra wear on things aswell because of extra kilometers i put on it.
I dont mind having too many problems, i like figuring them out and fixing them. Must say, regardless of the problems, this has been the best car ive had by far and wouldnt trade it for anything...
In other news, i put the black wheels back on it and it goes ok. I will be raising it after the weekend. Itll be tight but im gonna try and get it ready for a track day in 2 weeks...
Edited by 4ABHGE
dude i like the sway bar :D and screw the exams just hit the track :P
Thinking about it :P
knowing my luck i will have 50 exams in and around that weekend haha
Threw my other wheels on on wednesday just because...
i kinda like these wheels more than the other wheels :P
Did a fair bit on the car today.
Raised it 15mm and now handles exceptionally well!! Car feels natural around corners, really neutral and i dont have to turn the steering wheel as much as i used to when it was low.
Also changed the oil in the motor, runs so much smoother now, and I changed the gearbox oil to some Western Oil SynGear 75-90 and man is it changing slick
Car is heaps better compared to this morning :)
I have a surprise coming soon aswell :D
Posted (edited)
It appears as though I am losing brake fluid somewhere :s
Also, repaired a melted altenator connection, long story short its because of helping out some chick on the side of the road... -_-
...Never ending problems...
Edited by 4ABHGE
Are your pads wearing down? Pistons having to push in further pulls more fluid from the reservoir. See if the reservoir has no spillage out the lid, and check around your brake hoses too.
Fried your alternator connection while trying to jump start some chicks Delorean DMC-12 (the flux capacitor optioned model)? :P
Accidentally went for a drive a drive in the snow...
When is the next snow cruise i should be in for it. As long as no homework for school. sad face
lol, the snow was seriously a spur of the moment, ! as soon as we got up, it started snowing, then when we got over it, and started to head down... it stopped :o coincidence ? ;)
loving these pics of the car!
Thanks Mick :D
Hmm im thinking in June after exams? Lake Mt sounds good to me, ill invest in some chains for the rolla :P
Man, the whole cruise was kinda spur of the moment haha the snow was definitely meant to be as soon as we left the car park the sun kinda came out, cherry on top of a great day :)
Been doing a bit of work on the car the last few days.
Added the catch can, got my daily wheels rebalanced, sorted out a couple of leaks and fixed my constant cold start issues. Tomorrow ill do the other driveshaft and fingers crossed i can get a wheel alignment friday!
Pics err... eventually lol
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
