Hi all
got a 2008 corolla sedan and was just wondering what the low beam headlight bulb size is?
Thanks.
Are you sure about this?! because I bought some h11 sized bulbs, tried to fit on my corolla and it didn't fit? :s
just read the manual. ... unless your car didnt come with it..
didn't come with it :S but found it its 9006/hb4. grrrrrrrrrrrr
The mistake u did 'brah' is asking someone else when you cold of taken a few minutes to check yourself. If low and high beam are in the 1 bulb good chance the 3pin bulb is a h4
If its single more than likely it's h7 or h1, hard seeing it being h11 as these type of bulbs come with a twist in housing...
yeah well i'm clearly a rookie/noob, so I would not have known that. thought asking here would be more reliable than google...
Just a little tip for everyone, if you look along the top of the headlight housing toyota's pretty much always have the bulb type and wattage moulded into the plastic.
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
