Sydney Monthly Meet - Last Sat of every month at Villawood usual spot
Toyota Paint Defect Class Action
Can anyone join this class action? I have a Toyota prado 2007 pearl white, and nearly ever panel is botched. I never really felt like the paint could peel up this bad -
83
White Pearl Paint cracking & peeling on a Prado
Bit late to the party on this one, but I have a 2007 prado, my roof and lots of panels are peeling, totally would need a whole re spray…. and there is no way I could afford to pay for a re spray anyone know if you can join a class action this late? -
26
Changeover manual A/C for Dualzone climate control
I have a 1998 supercharged toyota estima aeras and was wondering if anyone has any pointers or experience deleting the rear ceiling air conditioner unit as I'm looking to make more ceiling space just wondering about the difficulty of it before attempting cheers -
Toyota Estima Air Conditioning
I have a 1998 supercharged toyota estima aeras and was wondering if any body knows the difficulty or has had experience in deleting the rear cabin ceiling air conditioner as I'm looking to make more ceiling room in the van -
Head Unit with Apple CarPlay
Hi Enforcer, Got a JVC KW-M56OBT 48% off at automotive superstore. My wife is super happy with it, lots of functionality, the Bluetooth microphone that comes with it makes phone calls crystal clear. If you choose to install it yourself you need to get wiring harnesses from Aerpro which are sold at Supercheap or any other car shop. If you choose to get one let me know if you are going to buy the Aerpro wiring harnesses and I will let you know which ones to get because it can get quite tricky I had to take some back and change over. -
Typical Price for a Replacement Key - 2000 Toyota Torago
Assuming it's expensive because you have no spare keys to make new copies from? Whilst your key doesn't need batteries and has no buttons, it probably still has a chip built in for the immobiliser to prevent hot wiring -
Invisible Instruments fix
Yep. I used that hack because the dash was so dark. It's brilliant and easy. Newer Taragos have backlit dash day and night so no more need for this hack -
Finally found all Tarago's 6 speakers - 2 in roof lining
After owning a 2007 GLi Tarago (ACR50), I've only just found there are 2 Tweeter speakers hidden under the roof lining just behind the front row (driver and passenger) seats, above the B-pillars. Blew my mind. Would really have preferred it if they weren't so hidden. Ideally they should have positioned them a bit further back too for the rear passengers to hear more clearly. Now that I know, I've been able to tune the stereo much better for rear passengers. Taragos were alway advertised as having 6 speaker stereo systems, but I assumed it must have been a marketing con because I could only find 4 speaker grills. Since the rear speakers don't have any treble sound, they really need those tweeters in the roof to balance out the sound. -
Can I use USB hub to get more USP ports?
I just bought 2022 Toyota Corolla Ascent Sport Hybrid. The manual said there are two USB ports, but I can only find one. I need two USP ports on the front: One for Andriod auto, the other for dashcam. Can I connect a USB hub to the USB port on the car, will Andriod auto work on the USB hub's port? -
Replace Front RH park light Corolla 2006
Hi Martin, Firstly welcome to the forum.. I would go on to Youtube I am sure there are many videos there showing the process. If you have no luck there google it and see if anything there can help out, I have never done it on a corolla but I do know on my Aurion it was easy on the right side but a real pain on the left with the battery in the way. KAA
