pulsar vs a sportivo????????????
Rear console dual cup holder
I need to replace the rear console dual cup holder in 2010 Hilux SR5. Does anyone know where I can find on utube? -
Ticking Hilux 5le
Hi all, got a 2004 diesel 4x4 Hilux with the 5le motor in it. 250,000 kilometres, i’m the second owner and have had it about 9 months. Since I bought it there has always been a constant ticking noise while driving (anywhere over 1200rpm) but not while idling. Does it while accelerating, maintaining speed and decelerating. No real impact on power and I get about 12.5L per 100km. I never worried about it too much but it’s starting to ***** me off a bit. I’ll link a video below, any clues what could be causing the noise? -
21
Toyota Echo Mods.
Hmm it seems like I can't quote anyone except the original post. @Wing (hope I tagged right person) I definitely relate. You did incredibly well with that find! Crazy low KMs! -
21
21
Toyota Echo Mods.
Thanks for the post Aldo. Googling echo upgrades lead me to this thread and now I'm a member. I definitely hear you. I've been looking in to turning my 03 Echo in to a soft roader. I bought it for 2k (clear coat was cooked) back in 2021. I managed to lose my license in it within first 3 weeks. I HUGELY underestimated how much up and go it has. Although on fresh tyres, previous owner went cheap. In the wet, driving hard, I was spinning until 3rd gear/ or around 75kmh. Have been playing around with it, looking at suspension upgrades, bash plates etc, even a snorkel 😂 but best I've been able to come across so far would be swapping suspension and wheels from a Jimny or similar. Would require a bit of custom modifications and therefore engineering certificate etc. There already seems to be some great posts in here. Definitely suspension and air flow seme to be the go. Since we have the old cable 🚠 based throttle, unfortunately we can't do drive-by-wire. I was introduced to that by a workmates 06? Hilux 4x2... That thing pulled *HARD* just from changing the mode selected on the DBW. V6 obviously but yeah. Definitely following this thread and gonna pop the air filter next 👍🏽 👍🏽 -
Wheels for Hilux
Hi, I'm hoping to buy a good second hand set of wheels for my 98' Mk 4 Hilux single cab. Does anyone know if Mk7 wheels would fit regarding the offset please? Thank you, Best, Daniel -
Removing low beam bulb 2014 Camry
Just wanted to add this here since I've just been through the very same dilemma and for some reason it's so difficult to find reliable info on the 'net for Australian cars. The globe does just pull out from that holder (referring to OP's posted photos). I was worried, too, and even found someone saying to undo those metal clips latched onto the sides of the plastic body. Mine was tight as anything but just had to grab the glass (it's actually quite strong - but be as gentle as practicable) and just wiggle the globe assembly back and forth while pulling on the globe. Eventually it will start to move a little and just keep wiggling and pulling until it comes out of its socket. What I haven't worked out yet is how to get the new globe back in the headlight assembly (on the passenger side with very limited room) without the new globe bumping into every piece of metal and plastic in that limited space and then how to get the holder aligned properly in the hole and pressed in deeply enough for it to latch (with a twist) back in to place. Possibly I didn't seat the globe down far enough when I inserted it back into that. holder. After that I need to tackle the front parking lights on both sides. So far (per a US video) I may need to go in from the wheel well? Crikey. -
Selling vintage 1996 hilux
Hey all, currently trying to sell my modified vintage 1996 hilux in sandy tourpe colour . Please message me on 0459246808 for details -
2020 Corolla service question
Hey guys! just purchased my first ever Toyota. December 2020 Corolla accent sport 2.0L with 32k on the clock. When I purchased it I looked at the log book and it had a service at 16’000km and one at 32’000km. Not thinking too much more about it after getting it I’ve realised the service between 16k and 32k was 2.5 years apart!! 😫 kilometer wise it’s not too far off but not having a service for 2.5 years is concerning to me as someone who’s very passionate about doing oil changes very regularly and keeping on top of my maintenance of a car! I can’t see any sludge or anything under the oil cap and it looks clean inside but I wanted to get your thoughts on any long term impacts this could have, and any suggestions on how I can rectify it! the last oil change was done about 2 weeks ago and I’ll definitely make sure I do another oil change no longer than in 6 months time. also what’s a good amount of time between gearbox services for a Toyota Corolla (intend to do it more often than what the log book suggests) -
7
Help - Blowing white smoke
Have you also given the vacuum hose a clean i.e.with a spray of de-greaser. Maybe be also give the throttle body a cleaner which may help to remove any oil related film in the intake. something else that i did was to fit an oil catch can which has since been removed. The real solution to fix this white smoke issue was to thoroughly clean the valve cover and also any oil sludge build up in the valve train. Something else that i did as temporary measure and to confirm that it was oil sludge build up issue was to temporarily disconnect the PCV valve from the valve cover. I taped off the pcv valve so it was unable to suck in an excessive amount of air. I also blocked the valve cover hole opening with some filtering material. The white smoke on start up should stop within a few weeks. If it continues, I would do another clean of the front valve cover with particular attention to the section leading to the pcv valve.
