Northy's Carputer
Northy
after seeing Tom's effort i decided to have a bash at it myself. So over the weekend i made the dash mount for the LCD putting it where the CD Player normally goes.
these are the guts out of the LCD.
here is the case of the LCD being put in place ready to start the process.
Sellys No More gaps - this stuff is just insane.
The result of the no more gaps
After it set i cut it back with a stanley knife
Over the top of the no more gaps i put some septone fiberglass bond to give me a sold layer to work off.
After sanding it back
Now put some of this on
and after sanding it back
After few more coats and sanding in between
now ready to put on some primer in preparation for the final coat
Some pics of the finished product
The plastic work you've done to make it fit is very very good. But, due to the size of the screen, it doesn't look factory. I wouldn't go as far to say cheap and nasty, but I don't know if I'd do it.
Still, kudos to you. I'd be working hard to make it look as good as that if I did it.
yeah looks crap - mine's better :P
nah man that looks tops.. like people have said, not a factory look, but a VERY clean effort... mine doesnt look anywhere near as neat as that :(
northy and i have been battling it out all weekend to make our respective screen mounts.. i just got a new screen.. we've gone in different directions so be sure to check out my carputer page for my effort when its done...
congrats again corey - turned out VERY nicely :D
great effort northy!
just outta curiousity, did you use the original parts from your car to attach the lcd or did you buy an extra 1 just incase you want to revert back to stock?
jase
Edited by JJCRU23R
jase
i just used the stock bits as the parts that i hacked up are the same on all the corollas across the range.
Northy the screen is very lovely, but is there any information on the box that's contolling all the goodies?
yep sure ill post up the full specs tonight when i get home
That Asus box looks pretty nice Corey. I've been looking at cubes and they are all too bulky for where I want to stash the thing, I have contemplated doing an MDF install, but realised it was too much of a pain in the *****. Nice compromise. :)
Asus Pundit P2-AE2
AMD Sempron 2800+
512mb DDR Ram
250GB HDD
DVD Combo
Intel Pro Wireless Card
Software is Centrafuse by Fluxmedia
where did you get the parts from? do you need to buy a conventer for 240v to 12v? which conventer do you use?thanks for your useful info.
TRD
  • 2 years later...
      Front Cameras
    3. 51
    4. 51
      1kzte throttle body
      Aftermarket parking sensor
    8. 4
      Head Unit with Apple CarPlay
    9. 8
    10. 1
