NEWCASTLE PICS ... 56k warning .......
300 series turbo issues
8
54
Stout Owners
New Member
Current Oil Specials
Advice Please
Fortuners Transmission
199
Times have changed post-COVID and no great bargain oil specials worth mentioning until now. Latest Repco catalogue has 50% discount Penrite Vantage Semi Synthetic 10W-40 Engine Oil 6L - VANSEMI10W40006. $35 for 6 litres is worth considering whether it will be applicable for your vehicle's engine and servicing requirements. Because most of my driving is short distance and as preventative measure against oil sludge, I use a comparatively short oil change interval between 3-6 months. It is a cost benefit decision. I use full synthetic for my long distance road trips. https://www.repco.com.au/oils-fluids/engine-oils-fluids/engine-oil/penrite-vantage-semi-synthetic-10w-40-engine-oil-6l-vansemi10w40006/p/A9611158- 1
