My Project...04 Written off sportivo.FINISHED!!!!
Replace a none working 12v accessory plug
Hi, Need help replacing a 12v accessory plug in the centre console of a 2011 Toyota Kluger? Thanks Amy -
2005 Toyota Camry Altise - changing transmission fluid?
I've recently come into the possession of a 2005 Toyota Camry Altise with 160,000 KM's and a spotty service history and have been doing some basic maintenance and repair work on it. Everything's been going pretty smoothly but I've been getting some mixed responses with whether I should change the automatic transmission fluid or not. Some people say that if it hasn't been regularly changed, the transmission may be worn and be relying on the particulates in the old fluid to make shifts. Does anyone have any experience or advice on this? -
2013 Rav SD card operating files for head unit.
Hi there. I have a 2013 Rav 4, the battery was disconnected for a couple of days due to a new transmission being put in. When we restarted the car we were asked for the SD card to load files to the head unit. We never received one as we purchased second hand. We found some files on here put up by a lovely user. They worked. We have the radio up and running but Reverse camera is not working. I am guessing we need newer file updates as they were end of 2012 ones. No navigation unit. Toyota dealer wants $270. Hoping someone on here has the files i need. Thanks. -
Automatic door lock
Why do my doors on my Camry Hybrid not unlock when I turn my car off. The areas in the menu that I'd need to fix this are not selectable. Is this normal ? I heard all Camry Hybrids unlock automatically ??? Confused 😕 Edward -
Error Codes - 200 Series Landcruiser
Hey guys, just wondering if anybody has had theres error codes - 7E8 and 7E9 come up on their 2009 -200 series Landcruiser turbo diesel. Any ideas on what they could be? Have tried searching online but am receiving mixed information. Any help is much appreciated- errorcodes
- 200series
(and 1 more)
Tagged with:
Android auto not working Toyota corolla ascent sport hybrid
are there anyone to help ? -
- 200series
(and 1 more)
Tagged with:
Looking for a set of rim's for my 80 series. What else will
What rim's will fit that aren't Toyota -
programming a new transponder chip
one of the remotes for my keys recently broke after I was out working in the rain so I decided to upgrade to a flip key that I purchased on eBay that was listed as compatible with my vehicle a 2009 Toyota Kluger kx-r. I was able to program the remote part with a combination of opening and closing the door as well as putting the key in the ignition and that all worked perfectly fine. However I am having some difficulty programing the transponder chip into the car in order to get it to start could anyone give me some advice as to how to do this as I have tried a number of methods with no results. Thanks -
Both license plate bulbs not illuminating?
Given that both bulbs are not illuminating, I would check the fuse first. Why? Because it is easier to do that instead of replacing the bulbs. From experience, when it has only been 1 bulb not illuminating, i start by either swapping the bulbs or just replacing the bulb first up.
