heres a pic of mine. just got it done today. mine is a prefacelift model. changed the lights to a facelift + jdm. not a bad turn out :)
anyway, i will give +1 to this thread! Very2 helpful! :)
also +1 to our WA mod, Kenneth for the info on where to buy the stuff :)
  • Replies 184
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Way to go Legend B)
now that is HOT!
i think its really good doing this mod, because it makes the back of the car more visible when under braking, plus add a Rear Spoiler with the LED's and you basically blind people because its sooo bright :P
Evo
Posted (edited)
Just opened up my tail lights to have a look at what needs to be done. Facelift model. Finding the last screw was a pain (the top one) but once I had everything off, the only things needed to be done was to solder a piece of wire from the brake light contact to the new one and put the bulb in. and drill/burn out the hole. Simple just need to buy some bulbs and I'll probably install it tomorrow.
A big thanks to jaderd for making this a whole lot easier =)
Edited by azzman372
Instead of soldering try this:
You'll find that the solder doesn't stick to well to the conductor plate.
So a couple of screws and a piece of wire on each side works way better.
Posted (edited)
Oh wow thanks and1. That looks a lot easier to do as i've been reading that most people have been probems with the solder sticking to the contacts. I'll give this a go and post up my results =)
Also go my bulbs from k-mart. $4.00 Austa Stop-indicator-reverse globe 12 volt 21 watt Item# 382
Edited by azzman372
Posted (edited)
Done!
Just to add how I did it.
I took the lights off the car and I used a soldering iron to melt the hole. Then I drilled holes on the plate and stuck the wire down it and screwed in a screw to hold it in place. Thanks and1 for that tip!
Pics:
No lights at all
Brake lights
JDM not done
JDM done
JDM!
No flash
Just parkers
With Brakes
With indicators
With reverse light
Edited by azzman372
Looks good Azz.. And your welcome :)
The rear end of your car looks very similar to mine now, except I debadged mine and resprayed the rear toyota emblem.
well ive just finished this mod the other day its relitively simple provided you solder and properly insulate the joins youll have no issues with it
**NOTE THIS IS A GUIDE ONLY IM NOT RESPONSIBLE FOR ANY ISSUES THAT MAY ARISE FROM THIS**
what youll need:
2x stop/tail globe holders i cut mine out of an old honda from the wreckers i got them for free
2x stop/tail globes bout 5-10 bucks
soldering iron
solder
drill if you really want
insulating tape or heatshrink
silicone gasget sealer
first pull out the tail light and unplug it from the wiring harness the inner lamp hole isnt cut for our models so itll have to be cut out you can use a drill to drill around the top to cut out the hole but i found just melting it out was much easier.
this is the part that needs to be cut out
this is the side i tried drilling i needed to clean it up with a soldering iron on the edges
the plug i used 3 wires one for earth, park and stop
the wires off the plug needed extending the wiring goes as follows
white/green stripe= earth
green/white stripe= brake
green= park lamp
these wires i refer to are the wires on the the tail light that you need to hook the extra light socket onto.
do not cut the wiring on the tail light just strip back the insulation and wrap the additional wires around them and solder them and either tape them up so they dont touch the other wires or use heatshrink if youve got it
putting in the globes seeing as theres no nodules to clip the globe housing into the tail light so i just melted the tabs off the sides of the globe holders
then i ran a bead of silicone gasget around the part where the globe holder goes into the tail light and simply pushed the gobe into the hole and waited for it to dry then reinstalled the tail light.
heres one side done
and both sides done
wow excellent, very easy to follow
Ok I believe that I am the first sedan owner to do this mod on this forum/have posted their results. I know there is already someone on owf who has done this.
Anyway this is on my prefacelift 04 sedan. I think its just as good as the hatch tail lights. :D:D:D
How I did it:
I got some sockets from the wreckers thanks to yuro and got my bulbs from kmart. Soldered out the hole for the lightbulb and stuck it in place with blutak. Awesome stuff that is. Then extended the wires and wrapped it around the contacts of the brake light and soldered it against itself. The contacts are the ones which have pins that poke into the wire and they come off. So I just wrapped the wire around it and put it back in (wish i took a pic)
Took about 2 hours in the dark with a torchlight
thanks for the pics :toast:
my car is booked in to have this extra brake light done with the audio work.
I will be using leds to go with the rest of the bulbs in the car.
:toast::toast::toast::toast::toast:
first sedan with this mod, Champion!!!
:clap::clap::clap::clap::clap::clap:
How I did it:
You almost fooled me.
From far, your car in the second picture looks like a Merc C-Class. HAHAHA
Well done with the lights :clap:
but why Toyota didn't have this throughout all the models in the first place, is the frustrating bit
cause itd cost extra on top of the price yadda yadda you know how it is
good to see so many people giving it a go never thought itd be so popular lol! guess ill have to come up with another diy
Posted (edited)
I did my JDM lights yesterday....
thanks to Azzman and and1 + the others who posted up pictures... it made it that much easier...
I decided to cut a hole instead of melting.... since the melting didn't look that appealing...
here's some pics.... didn't bother with too many pics as there is a thorough guide already on here...
Things i bought for $11.50 from BUNNINGS WAREHOUSE
1. 3mm metal thread screws
2. 3mm Fastners - hexagon nuts
3. male blades - with easy entry [part No. LT039-JK]
4. Narva Auto Bulb 12V 21W BA15s
Stock
JDM !!!
JDM !!
Edited by envykenshin
Really wishing to do this, have all the tools, only main park where im getting confused is the wiring up part, anyone willing to shed some detail on what to do? Facelift taillight btw, Take the tail like out, drill a hole in where the jdm light does, put the 12v 21w bulb in the buld holder (already stock on the facelift), and then comes the wiring...
Cheers if anyone has easy steps :)
Posted (edited)
Disclaimer: The following is provided as a GUIDE ONLY, i will not take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
Well u got the majority of it... the wiring..
I can help you if you're willing to drill and use screws [and1's method]
these pictures might help .. save them and zoom in for convenience....
[stole em from and1... hope u don't mind]
TIPS:
1. remove the buttony things shown in the pictures using a blade.
2. get a 3mm drill piece.. because thats how wide the buttony things are .. and get ur hands on 4....... 3mm width screws.
3. after this just find a way to tie the wire to the screw.. i used something called 'male blades' found at local bunnings store
4. the final thing is the fastner thing to hold in the male blade
AND ur done..
if ur confused abt the parts just take a look 2-3 posts up.
here's some visual aid
step 1. remove the two buttony things shown using a blade .. be careful!
visual aid
the back should look something like this when ur done!
goodluck.. credit to and1 and azzmans work. + anyone else who deserves credit LOL
edit: last image died, updated 16/08/2010
Edited by Chrono Trigger
Haha I'm surprised my method is becoming more popular. Its the easiest way I think.
Yeah, for the Facelift though
Evo
Kudos to and1 and jaderd. Why surprised and1? It is the easiest! :D I'll be doing this too
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
