Posted (edited)
Bought a Toyota Corolla ZRE152 in Feb 2010 MY09. Engine is 1.8 2ZR-FE
Photos
91.7KW, stock is around 70kw
Peak torque is around 227nm at 4400rpm (37% increase in torque)
With camshaft change, aiming to get 107kw at the wheel with more aggressive camshaft, it will shift the peak power band to 7000rpm, with some sacrifice on mid range
I am aware the dyno is just a rough estimation of engine output, and is not accruate
Stock with cat back only (Graph referenced from another member dutchie101)
Before and after Unichip, plus headers, full exhaust (include high flow cat), NST pulley, intake, pay attention to midrange
1102751_10153092689410697_246306651_o.jp
1102751_10153092689405697_1137915623_o.j
After LSD and flywheel and new pod filter (replacement, same brand and model), nst pulley removed. The 2 dyno lines represent two runs. First run is 89.7kw
Nqj7I-8eh0eKNquC9mcezNP2T1wIqkbRJEfOyCcp
CurrentMods
Power related
- Injen CAI (3-5kw increase)
- WeaponsR Header (2-4kw increase)
- Custom 2 inch Catback installed. (3-5kw increase)
- NST Pulley, around 2kw increase,  broke into three pieces after 50000km
- CatCo Hi Flow Catalytic Converter, with headers sitting so close to it, it becomes a bottleneck. (1-3kw increase)
- Unichip (7kw in mid range, 3kw at peak)
- MWR flywheel (6kw increase across the range)
Handling Related
- Bridgetone MY02, Toyo R888 for Track use
- Remsa Brake Pad or A1RM
- DBA standard rotors
- Peddars xtreme Coilover. 30 ways of Adjustment
- Cusco Front Struct brace to reduce body flex in tracking
- Cusco underbody brace
- KMAC 20mm Rear Sway bar adjustable
- Wiechers rear strut brace
- Peddars lower arm polyurethane bush
- Quaife LSD
Exterior:
- HID 6000K
- Front fog light
- Toytoa Europe side skirt
- Levin style spoiler
- Rear tow hook
- Auris badge
Engine oil: Nulon 0w-40 High Performance Synthetic oil
Reducing Weight
Remove all seats except driver seat (around 30kg)
Remove spare tyre and tools (around 15kg)
Light weight driver seat (5 kg reduction)
Lithum Battery, 2.9kg each, https://www.lithiumax.com.au/product-page/lithiumax-new-450cca-black-lcd-series-battery
Light weight flywheel (5kg reduction)
- Rota R Spec 16x7 (6.5kg each)
Work in Progress
Unichip i-driver to increase rpm to 7200rpm, our car is cut by fuel when overrev
MWR Camshaft stage 1, https://www.monkeywrenchracing.com/product/mwr-cam-set-2-2zr-fe-stage-1/. This will increase the peak power by 8% estimated
Below was done in 2012, where no flywheel, no LSD and no camshaft mod
462544_10151487973200697_1644008443_o.jp
Image may contain: car
Image may contain: car and outdoor
Edited by ben yip
Very nice and good seeing you in action at Wakefield couple weeks ago.
Nice to see you finally posting up a Member's ride thread :)
Love your exhaust setup. I really need to get mine rollin'
Excellent work Ben,we'll get some more pics up soon ;)
How much did the weaponR headers set you back man? And where did you source them from?
Posted (edited)
Some black Work Emotion CR Kai's would set it off! nice work with the car though :)
Plan to buy Enkei RPF1 16x7, only 6.2 kg each. Price is around 1k including shipping. Work Emotion is too expensive
$255 + shipping + install
http://www.autotuningstore.com/Weapon_R_Stainless_Steel_Street_Headers__421__1_Piece__953116109__Toyota__Corolla__From_2009__To_2010--product--161260.html
Dutchie101 and Johnnieboi have it installed
However, if you don't change the exhaust system, it is useless. For me, I will change the catalytic convertor to the high flow ones because the catalytic convertor is sitting so close to the header
The full exhaust system will be looking around $2k
Edited by ben yip
http://www.autotunin...ct--161260.html
http://au.toyotaowne...225#entry421749
Wow that's awesome. Thanks man. I've got my axleback done with the Xforce S10 twinloop at the moment and plan on having the stock cat+resonator replaced with a highflow cat and potentially later on will have headers installed.
Hey Ben go 16 x 8 +38 ! will give u a better stance also what color u getting ? I hope you're getting black hehe
Haha, I do not want to thrash my current tires, otherwise, I go for 17x7, 16x8 is rare.. I am looking for black or white, not silver
Weight is my main consideration factor, must be under 7kg per corner
Posted (edited)
Enkei's should look sweet!
Oh, if you're looking for lightweight how about 949 racing 6UL.. they're cheap and light!
Edited by clifton
Posted (edited)
Ahhh fair enough but I'm sure those tires will fit the 16x8 also try the site themselves. Here's the chart http://www.enkei.com/size_chart/RPF1.pdf
Accroding to this, I can either go from 5.5 to 7.5, which means I can only fit 6 or 7..
http://www.1010tires.com/tiresizecalculator.asp
No la, lightweight and ridigity or you end up the wheels being bent during driving in the following Enkei Review This review is quite good
http://www.m3post.com/forums/showthread.php?t=479110
Enkei is not pricy as well
I am already broke after I modify my car and go to track day!!! Start to become addiction
Edited by ben yip
16x8 in 5x114.3 is indeed rare. 16x8 are usually 4 or 5x100. :( I was trying to find a set of shoes for track... :whistling:
Quite the contrary dude. I've had both the Enkei RPF1's and also Rota Slipstreams; copy wheels of Desmond Regamasters'. I flew of the track at 130kph, spun 360 degrees and hit the gravel 2inch from the circuit and didn't even dent or bend ANY of the wheels even managing to lodge a stone inbetween my semi slicks and the wheels.. go figure.
then johnnieboi had to use chopsticks to get it out... ohh yeahhhh!!! :lol:
Posted (edited)
Please don't do this to johnnieboi,
johnnieboi, please beat the sportivo guys. We ZRE owners should not be bullied by Sportivos !!!
This is probably my choice for wheels, Rota R Spec, white colour (because my car is red)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300570729705&ssPageName=ADME:X:RTQ:MOTORS:1123#ht_2120wt_1165
updated: 6.5kg
or
http://www.ebay.com.au/itm/16-ROTA-FIGHTER-WHITE-RIMS-WHEELS-16x7-40-5x114-3-RSX-/300557012842?pt=Motors_Car_Truck_Parts_Accessories&hash=item45fa980f6a#ht_2188wt_905
updated: 7.7 kg
I am stilling waiting for their reply on weight, which I guess less than 7kg
I will also need to buy some red color nuts (my car is red)
Next week, I will change my catalytic convertor to see how it goes. Will dyno later to see the difference, looking for 82kw atw for all mods. Here is my stupid estimation
Base 70kw
Pulley + 2kw
CatBack + 2kw
Headers + 3kw
Catalytic Convertor + 2kw
Intake + 3kw
Edited by ben yip
I had a quick search and have found that they are 7.7kg but i believe they are just under 7kg, no one can really confirm it..
Also the gunmetals come in +40 and white in +45, I know it doesn't make sense but that's what I found :)
They are a good price though,are you still interested in the RPF1's Ben?
I can tell you, very hard decision..I am sure you know how hard the decision is for wheels
TO be honest, RPF1 style is not my style.
Here says 5.9kg
http://www.potn.co.uk/fighter-16-x-7quot-4-stud-fitment-white-with-red-lip-set-of-4-wheels-lightweight-series_p1040558.htm
but here says 7.7kg
http://www.ebay.com.au/itm/16-ROTA-FIGHTER-10-WHEELS-5-LUG-RIM-NEON-CELICA-TYPER-R-/370453341999?pt=Motors_Car_Truck_Parts_Accessories&hash=item5640bd672f#ht_4962wt_1139
Very good price, even with 7.7 kg, I am still thinking whether to go for it..Since I have to pay almost double for RPF1
Posted (edited)
deleted
Edited by ben yip
Posted (edited)
erm dude... You can't exactly compare dyno sheets from different dynomometers as there is a discrepancy of up to 10%. Not to mention the temperature and atmospheric pressures that plays a role on the readings. You say which cars make less power than your car ect, hell my car make 63.4wkw; 20+wkw less than yours but it'll be interested how we go on a race track, with me 200kg+ less..
Edited by dorifto
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
