bc br coilovers
hey guys i just ordered a set of bc br coilovers from justjap :clap: .
my question is anyone have a height recommendations i should have ( i want low but not alot of scraping everywhere i go lol)
also where should i take it to get them put on (cost wise and advice ) in west side melbourne.
cheers guys
pedders south melbourne. they've always looked after me. but yeah DIY and get them to do wheel alllignment if u can :P
the height? well i like an even gap between the wheel arch and the tyre. these coils won't let me do that though. though thats with weight on the back. if i take out all the weight i possible could the gap will be even again :) perfect for the conditions i put my car through :P
btw i like ur style
i would put it that low, if it wasnt not so practical and our roads weren't as sh#tty.
Yeh that low in Melb and u can kiss goodbye to your exhaust system over the half size cement speed humps. i.e. Nicholson St, Richmond.
Got my coilovers installed :) can fit my fingers into the gap but back is higher than the front lol. anywho ever since then i drove it for one day no noise has occured. the next day sometimes when i turn the wheel it makes like a rubbing noise first i thought the front was too low but it didnt look from the front it wasnt rubbing anything. anyone able to help me figure this problem out lol . also my front right cv boot is leaking if it helps also i havent got a wheel alignment yet
cheers
Edited by ptagna
Does it make the noise when you're full lock or close to it?
just whenever i turn it sometimes. even if its just like a little bit :/
Edited by ptagna
      Ae92 genuine low ks 70800
      BATTERY in Klugar 4 years old
      ‘97 Petrol 6 cyl ‘80 Series knocking/rattle below
      1989 Hilux Low Voltage
    9. 1
