Who's up for the drag day?
27 members have voted
Brand new Prado 2022 with intermittent engine/transmission stutter
Gday Doug (600C), I have a 2023 GXL that from new that has a ‘whoo-whoo’ sound at similiar revs that you describe. Its most anoying at 75km/hour in top gear under load ie. up a slight hill. Toyota guy cant give an explaination but says he drove another one with only 1000kms on the clock and did the same. Have you found a cure or diagnosis at all?- engine stutter
- transmission stutter
(and 1 more)
Tagged with:
Corolla 2007/2008 ZRE152 2ZR-FE Hood insulator
I immediately thought of sound deadener material which is available from JayCar as a potential solution. https://www.jaycar.com.au/combination-butyl-foam-super-sound-deadener/p/AX3689 -
Hi, I've tried to get a hood insulator from Amayama OEM suppliers and Sydney wreckers with no luck. Wreckers usually sell hoods/bonnets with them attached. I called Toyota and unbelievably. they sell them for $700 plus. Is there a way to repair? or get some insulator material to make my own? My one is crumbling and cracked. -
Issues starting first time, sometimes
Hi all, For some reason my 2012 Prado is having dramas starting first time every so often. Regularly serviced 192k KMs. Sounds really rough during initial failed attempt to start. Then on second attempt will start fine no drama's. Sometimes I can hear a little bit of that initial struggle during a cold start and will still start. Everything else seems to be running fine. Thinking it could be a fob or immobiliser issue? Have had the same result with both main and spare key fob. Booked mechanic in a couple of weeks for diagnosis but hoping to point him in the right direction. First video is the no start and the second is immediately after appearing fine. Cheers! cold start fail.mp4 success.mp4 -
1kzte throttle body
does any one know if you can buy replacement motor for fly by wire throttle body and what is the part number for kzn165 hilux -
Android auto
Hi, same. I have a Feb 2024 Cruiser. AA needs the cable to operate. Car Play works wirelessly. -
5
the toyota sienna is a DREAM. I wish they would make it here in australia and compete with the kia carnival. theres so many families getting into mini vans now, but we prefer toyota hands down. the graniva is UGLYYYY.- 1
5
Toyota prado 2018 Rattling noise?
HI Don, Did you work out the rattle noise? Having the same issue Thanks Stephen -
8
PZQ60-00525 Issue
I can confirm this worked for installing PZQ60-00345 from a 2020 70 series landcruiser into my 2000 100 series. It's an old thread but the only fix I could find - so bumping up. -
Gasoline smell in cab when driving
Hey mate! Hoping you’re still here. How’d you go with this? Currently trying to diag the exact same thing in my rzn169r 4x4 2.7l hilux. Smell is getting pretty unbearable but all fuel lines are dry and nothing obviously wrong with any vents or connections (on the surface at least). No smell when idling. Mostly just while driving, especially after a long stretch at high speed or uphill. Noticeable inside, most strongest in the rear right passenger seat - right near the fuel door.
