hey guys
i just recently been talking with one of the mechanics in melb
they said that with a light weight flywheel there will be a definite loss of torque
can anyone of u who have a light weight flywheel prove or contradict this?
any dyno charts?
You don't lose tourqe man. Infact, with lightweight flywheel the respond of the car is far better. Perhaps what your mechanic was referring to, was going upshill. Going uphill with lightweight flywheel causes struggle, but that depends on how light your flywheel is. On a straight, all you get is improvement.
the flywheel will make the car rev faster, but if you are doing alot of uphill events/driving then a light flywheel may not be the thing for you, you can lighten the flywheel and you will feel the diff.
specblack the night you were there and i sold the used flywheel/clutch the guy told me after he installed it "so happy with it because the car is faster and more powerful especially low rpm"
A lighter flywheel will give u more bottom end power, but less upper end oomph. better response and faster acceleration.
A heavier flywheel will give u less bottom end power, but more upper end oomph~ :D
I was told it was more difficult to launch hard with a flywheel (More chance of bogging). However powerwise was an improvement especially down low like kcorro said.
Let us know when u get it done :rolleyes:
Search and you'll find comments from many happy on this forum... To name few:
Peekay & Ilivfor6 (when they did own Sportivos)
Screaminrolla
Northy
Very simply, a lighter flywheel will spin up faster, but will also lose intertia quicker too. So the car will rev better and be more responsive, but the revs will also drop quicker between gear changes, for example.
Posted (edited)
great great
thats all i need to know
because with the low torque we have on our sportivos
losing more is just a pain in the a$$
EDIT:
one more things guys
the mechanic also said that with light weight flywheel + passengers in the car
it'll make your car go slower
i know that with extra load even with stock flywheel
the car doesnt pull as well
you guys with the flywheels notice any diff with passengers in a lighten flywheel compared to stock?
Edited by spec_black
i get that guy who bought the flywheel/clutch to meet you ok? pm me your email
with the lighter flywheel, u go both ways quicker. the revs will rise faster, it will also drop faster.
if u're going up a hill, with the same throttle position as a car with a stock flywheel, your revs are going to drop faster.
if u floor it, your revs will pick up just as fast. most of it is engine response. i found the flywheel to be great. it's one of the best mods to do, coupled with a clutch kit. i never ever found it wanting or ever felt it had a lack of torque.
it's a bit tricky to launch the stivo with the lighter flywheel and the clutch kit. just invest a bit of time to practise. get it right, and u're always at least half a car length ahead of a stock car when the light goes green. however, it doesn't make it any easier to keep the car in lift. so if u have stiff suspension, good tyres and the drivetrain bits, forget about doing the lift shift.
the other tricky thing is when u have to lug the car around the carpark with a/c on. u just need a little bit of dexerity with your left foot so u dun fry the clutch or stall.
it's a good mod.
yeh what everyones saying makes sense, lighter = less inertia = revs drop faster, but lighter = revs climb faster, i've always wondered why the TRD flywheel wasn't the lightest around, i guess thats the "optimal" weight. but it also seems that a better clutch is the perfect partner for the flywheel, to cut back on those revs you'll drop
And i heard the members who had their flwheel/clutch replaced, the gear /boxshifting issues are gone?
well, since the labour cost is quite significant. u might as well get a better clutch, too. coz with the lighter flywheel, u are going to be slipping the clutch a bit more and the slip rate would be higher.
on the phantom it solved all shifting problems.
i discovered that :unsure:
you dont have to worry about that
clutch on its way
just deciding on flywheel right now
Posted (edited)
The following are some brands that make lightened flywheels for the 2ZZ :
Fidanza 3.4 kg
TRD 4.4 kg
TOMs 3.8 kg
JUN 4.4 kg
Toda 4.7 kg
C-One 4.5 kg
note the following weights are for the 2ZZ flywheel, the 1ZZ has differnt weights
Edited by wei wei
Fidanza        3.4 kg
TRD            4.4 kg
TOMs          3.8 kg
JUN              4.4 kg
Toda            4.7 kg
C-One          4.5 kg
I hear that Fidanza is great for track but it's rtoo light for daily driving. So personally I'll go with either Tom's or TRD.
btw, if anyone here has the part numbers plese PM me and I'll post them up.
the TOM's flywheels make some intersting noises, anyone that has herd a car with one will know what i mean
I hear that it sounds like a chainsaw, especially when starting up.
What everyone said about the flywheel is pretty much spot on, much better throttle response. Great mod especially when you are considering a new clutch kit. The TOM's flywheel makes the most peculiar mechanical sound at startup, sounds very different to every other flywheel but it works great. Like what Shao and Northy said, I did find that the clutch slips more when trying to take off but you just need to find the right technique to launch and shift. It can still stall on you very easily as eveyone that jumps in my car for the 1st time stalls it, no fail.
Didn't notice anything much different with uphills or with passengers. Just rev the thing if you feel underpowered, that's what the 2zz is made for isn't it :D
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
