[QLD-BNE] JZX-100 Chaser : Weekend fun - *RIP*
JDM101
I used to be on this forum a long time back when I was new to the community and the car modding game itself. It's been quite sometime now, have been lucky enough to meet some genuine people in the crowd of cybertrolls and what not :)
So here's my take on doing up a JZX100...
This will be a lengthy to the point thread so I'll try get through it all...
then:
DSC_0037.jpgFrom:
To:
I didn't like the Series 1 bar:
comparison:
First dyno run:
http://www.youtube.com/watch?feature=player_embedded&v=7YeTkNO0eHU
Got rid of the HKS canon:
http://www.youtube.com/watch?feature=player_embedded&v=AAvj6AB32Mg
Had a change of mood so decided on some other mods (besides cleaning it)
Auto had open wheeler 3.9 ratio, got it a torsen from a manual (3.7 which I still have to change to 3.9)
While I waited on more parts, went to the drags:
lol..
results:
Turbo coated:
getting there..
random interior shot for no reason lol
some brakes:
did a service:
oh yeah it had a cooler install too:
I went to the drags again, only one run - untuned, just to see what it does:
most recently:
results:
Edited by JDM101
I got bored with lag...
oh haii gaise !!
Gaise?? where'd you go??
Needs new o2 sensor me thinks
Edited by JDM101
Previously:
and now ..
then it made its way home:
yuck..
and then..
Didn't forget these bits too:
412780_520286061361790_979657456_o_zps24
Needed new bearings.. fk that why not get all the new bits? make it drive like new..
and a money shot with the family barge
Edited by JDM101
Summary:
- New Koyo copper rad, think it's oem spec though not larger
- New Koyo oem spec condenser
- TRD thermostat
- Rad. pipes
- Gt3076r .82 divided housing ceramic coated
- Split pulse manifold high temp coated
- 3.5" dump mild steel
- 100cell Magnaflow cat converter
- Magnaflow rear muffler
- Amuse ETCS
- Hks Dli
- B&M Transmission cooler (factory line modified so it's no longer pointing towards the radiator)
- New oem O2 sensor
- New K&N filter, no more stalling as the distance from intake to afm is a little more than previous setup
Parts used from previous setup
- Id725cc
- Walbro GSS342
- Tial MVR 44 with .8bar spring loaded
- Hdi EBC
- Hdi cooler with custom one peice aluminum pipes
- Turbosmart plumb back bov
- Mid muffler
- Emanage ultimate
Massive thank you to Mr JP aka CHA54 around here - you all know well who he is..
Craig @ Extreme Custom Engineering + Mattyshop (think that's what his nickname is on here)
Sean @ EFI Performance
The car is much more fun with the response based setup.. I haven't mentioned the suspension mods as it took a while to get all the details above :P .. nowadays just focussing on replacing all the smaller parts .. mostly oem and to ensure it's all reilable and quality..
Cheers for viewing.
Edited by JDM101
Thanks ^_^
Charts for reference:
Video of what looks like how mine would go too... :ninja:
Suspension and drivetrain mods:
- DBA 4000series rotors upfront
- Dixcel OEM spec rear replacements
- Project mu front/rear and hand brake shoe pads
- MV Automatics shift kit
- B&M Trany cooler (don't want my tranny to get teh heat aids)
- 4.1 ratio torsen lsd (gear ratio from hilux)
- Toms front chassis braces
- Cusco strut brace
- Cusco front sway bar
- Cusco lower triangle brace
- Cusco front upper control arms (yet to be fitted)
- Complete new OEM hub parts (bearings, seals, etc)
- Aftermarket aluminum oil pan guard
- TRD castor arm bushes
- TRD differntial bushes
- TRD Camber arm bushes
- KTS rear sway bar
- 501 works chassis to diff cradle brace
- Adjustable rear sway bar end links
- BC BR coil overs currently in it, travelled less than 3k kms and I got bored of them so Fortune 500 incoming 12/8 kg rates.
- 18x9.5+30 Work Emotion 11r wrapped in 235/40 gForce profiler rubber (need new tires lol)
Exterior:
- Series 2 front/rear bar with OEM lips
- Sideskirts are the same for S1/S2..
- Bar the doors, all other panel imperfections were removed and resprayed.
- Factory spoiler removed, pending a carbon fibre bootlip
- Pending delivery carbon fibre front grill
That's all I can think of - there are some other bits but will fit them in first then update here.
Edited by JDM101
Thanks for the positive comments ^_^
hit a bit of a snag.. the cf grille doesn't fit 100% .. should've known better than to buy off Ebay Hong Kong ... getting a full refund but ofcourse I need to cop the delivery fee back..
A fellow JZX100 mate has been kind enough to donate me a standard replacement.
I'll be getting my car detailed by https://www.facebook.com/autoglamour?fref=ts - this Wed.
Still pending new coil overs, front upper control arms and some smaller interior bit from Amayama. Should be ready for its feature photoshoot later this month :ninja:
A while back I discovered detailparadise.com.au and I was fascinated by the work I saw there .. here are some examples naturally I HAD to get me some of that kinda exterior loving..
You can find a detailer for your area here
I met the detailer from the link above and due to his helpful nature and cool attitude towards car modding; I made it my aim to refer any and every possible detail request his way..
So far I've had my Civic done, my cousin has had 5 of his family cars done (sisters/parents) and Quarkz's ex-Chaser was also done by him.
As I was never 100% happy with the panels on my JZX due to the minor imperfections so I didn't go ahead and book in a detail .. that was back in 2010.. Now after having had all the imperfections removed from the main panels and sprayed.. it was time..
Today I went to drop it off and enjoyed a scenic drive..
Everyone seems to be a baller in this part of the hood
and here I left it all snug
I'll be picking it up on Thr evening / Friday evening .. possibly will get my other barge done too.
Do you like crusty badges?? nah I didn't think so - naturally Amayama you done it again!! <3 if you reading this Justin .. keep up the ****
fantastic work..
Edited by JDM101
Think your car is clean? - take a closer look and WTF (right side of the pic)..
eagerly await more pics...
That is an epic result...
So as the ebay supplier turned out to be a headache... and I promptly sent the grill back as they agreed to refund me.
Was rather annoying but a fellow JZX forum member stepped up and became my hero when he sent me his grill.. dude didn't even let me pay postage...
and Jesse Streeter is the mof'n legend...
For the JZX - the Cusco arms, new chamois set, TRD shift knob and a Rasberry Pi board which I intend to convert into an obd reader..
Edited by JDM101
Just need the front badge and that should finish it off the way I like.
Incoming front end suspension refresh on Tuesday:
- New oem tie rod ends
- New hub components, seals, hub, bearings basically the entire hub replaced
- Cusco upper control arms
- New oem front brake dust covers
- New oem ball joints
These bits will join the existing party which consists of:
- Cusco swaybar
- Cusco triangular bar
- TRD caster arm bushes
- High tensile bolt replacements
For anyone curious what about the rear.. that's already been sorted a while back
- TRD diff bushes (4 piece)
- TRD camber arm bushes
- Ikeya cradle mount inserts
- 501 works diff - chassis brace
- KTS rear sway bar
- Adjustable swaybar end links
- Every single bolt replaced with either new oem or high tensile aftermarket spec.
I MIGHT consider silk roads camber/toe/traction arm set else I'll get KTS in the event I need such adjustments otherwise wheels sit fine as is and oem holding up solid.
Unlimited cash supply?
I wish :p ... but honestly - the above parts didn't cost as much as they sound they would've.
I see you've already read my little write up here - check out prices there too :) , you'll be surprised.
Edited by JDM101
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
