underbody flaps
I took my flaps off coz it kept rubbing the ground :P
Mate there is surgery for that kind of thing. A bit of a nip and tuck should rectify it ;)
It wasn't put there for no reason.
Just like the rest of the plastic covering the underbody, the 'L' shaped bit of plastic is to provide more downforce when travelling at high speeds.
By theory, sportivos should be more stable than normal 'open bottom' corollas at high speeds.
Simply study the underbody of sports cars, or more simply, why did CONE make the underbody plate?
cheers.
cheers.
the way they are facing would create lift rather then downforce tho....
Yeah that make sense. Afterall, the Toyota bodykit actually have aerodynamic purpose ( I forgot who or where i read that). So What pippy and 1zz-fe said could be valid.
Oh yeah, even the TRD front bumper (the one that looks to have smiley face) reduce more drag co-ef! Technology from its Supra JGTC!
cheers.
It actually encourages the air to go around, i believe.
watch more best motoring, they explain it very well! :)
      New Vehicle Key Remotes
      Help with Head unit Upgrade ?
    3. 8
      Just had new alternator installed and reverse camera has los
      Part Wanted for 80, 100, 105 Series Landcruiser Spring Cap
      2016 Aurion Sportivo rear speaker removal/replacement
      2016 Aurion Sportivo missing electric blind button
    8. 88
      Aurion 'Pull Left' Issue Explained
    9. 3
      New member
