186 -
Days Won
8
Content Type
Profiles
Events
Gallery
Tutorials
News & Articles
Videos
Everything posted by Aurion ZR6
2009 Aurion blowing smoke on acceleration
Aurion ZR6 replied to I know nothing's topic in Aurion / TRD Aurion Club
I change my oil every 5000 kilometres including oil filter, I've need had a problem with oil sludge! Oil very black at 5000 kilometre, I don't know how you let it go to 10000 kilometres.- 36 replies
- aurion
- acceleration
(and 1 more)
Tagged with:
That got done back in 2008, aslo has the Cooling oil lines to external oil cooler replaced out of warranty, 2020, still going to strong with 89000 klm, I hardly drive it now.
My 2006 Aurion with 86,000 Kilometres on the clock, finally the Water Pump Sh*t itself today, cost to replace from Toyota was quoted at $750.00. Hope to have back to 2 day's time.
Engine Oil cooler Pipe & Hose assembly Recall
Aurion ZR6 replied to Aurion ZR6's topic in Aurion / TRD Aurion Club
Mind getting replaced I've slight leak on one hose. -
Receive a recall for for 2006 Aurion. Aurion vehicle with 2GR engine use an engine oil cooler assembly to maintain optimal engine oil temperature during all operating conditions. Toyota has received some reports that an engine oil leak or seep may develop from the oil hoses between the oil cooler and the engine. Should you experience a leak or seep from the engine oil cooler pipe, please contact your preferred Toyota dealership for diagnosis and repair. Toyota Dealer will replace the engine oil cooler pipe and hose assembly with an all metal oil cooler pipe, free of charge to you.
Try someone like this https://www.gumtree.com.au/s-ad/alexandria/audio-gps-car-alarms/repair-of-lexus-toyota-navigation-dvd-error-system-unusable/1177013081 But as you can read it saying the DISC MAP is unreadable.
That version V22 "short version" from that URL willn't work unless you load the original Toyota disk first, then you can load the V22 disk. I'm running V22 currently.
Update, still leaking, but I found the cause, I remembered I had the Sunroof, repaired, and guess what the tube had fallen off on driver side. Bloody Toyota dealership, I could kick them up their b*m. No more leaks.
40psi front 36 psi rear.
Got the same problem on Driver side, I cannot see where it coming in, I do have a sun roof pipes are clear. I think I will check the passenger now, that your is leaking as well.
12 year old, 2006 model, oil change oil every 5000 km's with Full Synthetic, because I only drive that much in 1 year or less. 82000 km's on the clock and still run like new.
Passenger Electric Seat - Need Help Wiring
Aurion ZR6 replied to L4WL3SS's topic in Aurion / TRD Aurion Club
That my original diagram, if you have Oem camera, there should be a plug in the boot around the camera location. If there No wiring between camera and head unit, then cut plug off Oem camera and wire to this diagram. This diagram is base for an aftermarket camera i.e: https://www.aliexpress.com/store/product/Waterproof-Car-Camera-HD-Car-Rear-View-Camera-Distance-Scale-Auto-Parking-Car-Backup-Reverse-Camera/430297_32819721475.html?spm=2114.search0104.3.15.49d42b3ftLvu3u&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10130_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10307_10131_10132_10133_10059_100031_10103_10624_10623_10622_10621_10620,searchweb201603_55,ppcSwitch_5&algo_expid=3198d0d4-625b-4789-83c4-9c63b7543158-2&algo_pvid=3198d0d4-625b-4789-83c4-9c63b7543158&priceBeautifyAB=0
I change my oil & oil filter every 5000 kilometres, since new, had transmission serviced at 45K and to be done again at 90K, No leaks, have replaced coolant once, everything else still in engine bay as from factory. Had the brake pads, and brake fluid at 75K, car only do 80K since new, My mechanic said you look after it very well, you have it for the rest of my life.
Same hear the original tyres squeal when they get low.
Aurion Oil Filler Cap Gasket? Need part number?
Aurion Oil Filler Cap Gasket Part number: TO-9043037140 cost $2.75 -
Just rang Toyota they have the gasket in stock. -
You're kidding me, all I want is the rubber insert gasket to oil filler cap, as it leaking a little bit? -
Can't get a replacement VVTI Oil line?
Aurion ZR6 replied to Aurion2Envy's topic in Aurion / TRD Aurion Club
Thanks as I now can see it is 1 part and not 2? Cheers Drew -
Does not make sense, as I say there 2 metal oil pipes, can someone else please answer. -
Can anyone point me too in the AURION MANUAL DVD of which heading to look at the breakdown of the actual "Oil Cooler" lines as I look under "Lubrication" and it not there. Or could someone list the part for metal oil cooler replace lines and gasket in number of quantity required, as it is a vague at what to get? As I can see there 2 metal oil cooler lines and there would be 4 gasket or I'm not seeing it wrong? I would appreciate your help thanks, as this way I can order all the parts at once, via Amayama Cheers Andrew -
Hi Everyone. Just becauses with buying off Ebay, as there are seller who are selling bodgy spark plugs, especially the Denso FK20HR11. Why because if you can see in the picture you will notice the tip missing under the electrode u end? http://www.ebay.com.au/itm/Set-of-6-Pcs-90919-01247-Iridium-Spark-Plug-For-Toyota-Lexus-V6-3-5L-FK20HR11/281921146784?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140117125611%26meid%3D5c8f985f6f4f45da821121f7303b193d%26pid%3D100009%26rk%3D4%26rkt%3D10%26sd%3D182017838264 These are faulty plugs been sold on the black market.
Hi Guy' & Girl's please read the different between these 2 front pads, this bulletin news is from Bendix: Comparing DB1474 to DB2243 for Toyota Camry / Aurion V40 I hope everyone is use the correct type?
