I have a similar spot in my house...should i commision an artist to do one of my Aurion,say mashing it down the freeway in the wet. :P
Bedroom ceiling :P
Bedroom ceiling :P
Naaaa... A mirror should go there. :lol:
Stupid question again from me: Ethanol blended fuel - best avoided, or ok?
Also, on the topic of fuel, is anything above a 95 octane fuel a waste in a 16v smallport 4AGE like in my 'rolla, or is it worth spending the extra to put in 98?
Say I have a Raid setup using the following ingredients:
2x Identical hard drives
Raid capable motherboard (using onboard Raid controller)
Raid 1 setup
Windows 7 install
In the event that one of my hard drives fail, does the other hard drive carry on as if nothing happens or...?
now, another stupid question from me:
how tight should you do up the sump bolt? i'm guessing tight so the washer crushes is too hard? LOL.................................................. -_-
Posted (edited)
nar tighten it till it goes loose again and then you know your right
Edited by ELEGNT
Raid 1 setup
Windows 7 install
Thats pretty much RAID 1 in a nutshell IIRC. Been a while since I looked at RAID so I'm not the most reliable source. As far as I remember it, RAID 1 is pretty much 2 drives with identical information, so if 1 dies the other just keeps on keeping on. You just rip out the dead one and replace it and the system will automatically mirror all your data over to the new drive.
Do Birds Drink Water? :spiteful::spiteful:
Use are probably thinking what an idiot well maybe thats what i thought when my freind 20 years of age owned a bird for 3 months asked me that.
yeah cuz i went to buy the sump bolt washer from toyota (bloody 1.50ea). the guy said that i'm supposed to change it every time i drop the oil. :huh:
well i can tell u guys that mine lasted 7 yrs before i crushed it and it was plastic, not metal like the ones i bought last couple of weeks. (that is of course the original one was replaced by the plastic one i had on my car)
Lol your toyota is a rip my toyota gave em for free :clap:
Seeeing as we have a lot of "stupid" questions, but not so many "stupid" answers to said questions, is it time to open a "stupid answers" thread? lol
While technically you should have a washer, I haven't had a washer for the last 30000km on mine :P
The sump bolt doesn't hold anything on. Just do it up firm so it wont rattle loose. I can't stand sump bolts that have been torqued up to 11ty billion Nm.
Stupid question for me
What's a single ray lens & double ray lens. What's the difference and how is it better?
And has any1 heard of the term hella 1 and hella 2nd generation?
When installing speakers (+ the crossover) into the door panels, in terms of electrical safety; what should I look out for?
Also, same question applies but to the headunit?
Just have any exposed wiring insulated to prevent short circuiting. With relation to speakers in the doors, just also make sure the wiring/speakers are clear of moving parts of the window. Apart from that, there is nothing else you really have to be careful about.
The doors usually have a plastic sheet of some kind inside them, handy reminder that everything "outside" of that sheet will most likely get wet when it rains, so try and avoid running wires there or cutting holes in the sheet (or ungluing the sheet itself).
Here is my stupid question, when locking and unlocking the Aurion, does the beep beep sound come from the same speaker as the horn or is it separate?
It comes from a little piezo on the back of each headlight. One of them is circled in the following photo. The blue and white wires to the side of it are what runs it:
What's the chance of getting a punctured tyre? Thinking of taking out the spare tyre but don't know if it's worth the risk.
Murphy's Law mate.
The entire time I had my last Aurion and my Camry, I had not once required the spare. I did get a few nails in the tires here and there but it didn't cause a leak. It was only during a rotation that I found them.
But, the moment you remove your spare, the chance of needing it will probably increase.
What are you planning on doing?
Murphy's Law mate.
Fill the spare tyre compartment with DELICIOUS CANDY AND COOKIES :toast: :P
Thought i would save some weight but i guess it's best to keep the tyre there.
1400 (or whatever the Aurion weighs) - 25kg = still heavy.
More like 1600kg, but the point is still valid.
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
