more air? more power?
kwach10
Previously discussed ways to get more out of the super V6 include free cold air intakes.
Here are links to a few items that might do it, assuming same fit as for Aurion.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...T&viewitem=
or these with factory-like fit
or this one for the old model
In some cases the postage can be more than the part, unless free-posted to the US/Canada friend who then sends normal post or delivers personally.
oh yes, it would be nice to know the difference it makes
one thing though, the factory warranty may be void???
Although it can be removed before going for a service :rolleyes:
Interestingly, when u visit service/parts dept have a look at the little announcement by factory about TRD parts.
Apparently, these are only suitable for racing and do not carry factory warranty and and may void factory warranty. <_<
Modding a NA engine is a waste of money. It will do minimal to your power when you change the air filter or even cold air intake. An extra 5kW at most?
5 for a pannel filter maybe not a CAI
there is no brains in pumping your boost up on your already turbo car.....u can get some cronic power out of NA's....ported, polished, blueprinted, headwork, cams, stroking, ITB's, bigger fuel pump, high pressure injectors, EMS, ignition systems.....i could go on forever....if you did all that to an NA engine you would scare yourself :ph34r:
Edited by ELEGNT
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
