Kenshin's Rice Rocket
Kenshin X
Long time no update...
Swapped my Evo 9 battery with Dyslexik's S4 Bosch Mega Power battery. :)
Also changed over those boring 2 pin style windscreen washer nozzle with the Camry Sportivo Washer Nozzle from the same era as the corolla.
Before
After
Loving the fanning of the water rather than just two streams of water coming from each nozzle :)
Me likey those washers, I hate the ones I have at the moment. Had an VEII SV6 as a hire-car the other day and it had the washer jets built into the wiper arms. which is an ingenious idea (very rarely drive new cars so not sure if this is now common or not)
don't really know if its common or not man... :(
anyways, today i took on a big job on paint correction on the bonnet. i was going to only do a part of the bonnet but what the heck... took me around 4 hours -_-
excuse the splatter :P
maybe this ain't a good pic either...
but when its clean...
lovely... :wub:
now to find time for the roof... <_<
OK. After a lot of cuts and cursing I finally got this thing...
inside the engine bay...
Got rid of those old pipes and replaced them with new ones...
and got brass reducers for heat resistance compared to plastic ones from SCA
cleaned the intake plenum again as it was already got oil sitting in there -_- but i didn't take it out this time. i just stuck a rag in there and poked a chopstick inside and cleaned it haha. now i dont have to worry about it anymore. except i got his problem here
http://au.toyotaowne...plenum-problem/
anyone know if this is normal?
just did a compression test today thanks to filit:
1st Cylinder - 190psi
2nd Cylinder - 195psi
3rd Cylinder - 195psi
4th Cylinder - 198psi
dunno what the benchmark is but it seems ok? lol... -_-
edit: oh shit i forgot to do somethings when doing the test... looks like i have to do it again lol -_-
This...
plus this (thanks to centreline suspension in thomastown)
hopefully equals PB on Sunday LOL
And on to other news...
This so i don't have a blonde moment and loose the fuel cap or drop it down the drain or something stupid
...and this to make some asian ass happy <_<
Well, the kermit's return to the track and man what a disappointment that was... only managed a 1.53.19 on the 9th lap of the day. Brakes and gearbox didn't like me at all so i tried to change my driving style but had to pull out early and rage quit for the day. It wasn't my time and the weather was so fine... :( i couldn't use the new suspension setup to its full potential. but anyways some pictures thanks to phillip who accompanied me on the day ;)
return in may for exe? ummm hehe...
To be 6s off your PB, something must have been majorly wrong. Brakes won't make that much difference on their own. How was everyone else fairing on the day, the general consensus a slow day (dirty surface)? Any oil/fluid down? If the tyres are the same I wouldn't be blaming them for that. Probably a lot of minor thigns adding up. Like heat, tyres slightly older, dirty track surface, not in the groove, down on a bit of track driving (you can lose pace just like losing fitness).
      Wobble at the front
    2. 7
      Brake issues
    3. 10
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    4. 25
      RADIO CODES "HELP"
    5. 17
      Wobble at the front
    6. 11
      rear wheel arch hole covers (3rd row seats removed)
      2013 Kluger grande Bluetooth music issues
      2010 MANUAL Prado with high speed acceleration hickup
      Fuel filter change - start stops running
    10. 10
