Evo's 1zz
Evo7
RISE FROM THE DEAD! :P
i have been given some paint, and am going to paint a new colour on the facade/ plastic bits inside the car lolz XD from silver to...? ;)
wish me luck :D
Evo
No Update.... :unsure:
i'm guessing this was a FAIL mate?
not so much a Fail Lee,
it just didn't turn out how i wanted it.. i painted it Gold metallic but its a bit darker then what i expected, but still makes it a bit different :D
more a dark Gold, then light gold...
Evo
  • Replies 988
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
this car shall from here on in be dubbed "FAI1ZZ"...
works in two ways...
FAILS (but in hektik speak)
and
FAIL 1ZZ (which is true in every way possible)...
:lol:
just kidding evan.. :D
post up pics... what paint did you use?
been thinking of doing the falcoon... but cant decide on any colours... :(
Hey guys,
i require your expertise.
I want to have a bit of colour under the bonnet, but not sure what to go for?
suggestions???
GO!
Evo
Myself, I'm not one to go with coloured hoses and paited engine bay bits (extra money I could spend on go fast bits). But you could go with The Wheels option and go crazy with a can of matt black spray paint.
I was maybe considering colouring the rocker cover. (NOT rocket cover LOL :P)
tips are good, keep em coming :D
Evo
remove the plastic coilpack heater and paint the cam cover ;)
I have lolol :P
i am talking about the cam cover... been thinking about some colour under there... crinkle red?
does the cam gasket need replacing if i take it off?
Evo
your engine should be fresh enough that the rubber gasket and plug tube seals will still be soft. You need a tube of form-in-place gasket to re-seal the half-moon corners at the cam part of the gasket when re-assembling. It's detailed in the service manual.
Time for an update,
latest and greatest mod so far:
from this
to this
Still need to figure out how to tidy up the wiring more...
Evo
why is there a filter on the tube coming off the CAI? That would be introducing unmetered flow to the intake and messing with your tune...
Paint looks good.
Paint looks good.
The bung that i had on there, which was just a cap off a bottle had gradually started to melt, so i had to do something about it...
i have had it on there for a few weeks now, and i haven't had any problems... do you think i should remove it? what can i cap it off with?
Thanks for the compliment :D
Evo
I'd definately cap it, it will be messing with your air fuel ratio's quite a bit.
Should be able to get a rubber cap from industrial plumbing places, Pirtek, Enzed, LHS, or use a section of rubber hose with a bolt jammed in the other end, etc etc.
This has got me a little worried...
shame, cause i liked that air breather thing :( how bad do you think that the a/f would change with it on?
cause, if anything, its running more on the rich side, you can smell the fuel sometimes :P
Evo
From CHA54 above, took your advice about removing the air breather, and have plugged the hole with a rubber stopper.
car was playing up yesterday on idle, so we reset the stock ECU and it runs fine, comes on boost alot stronger, and idles perfectly.
thanks for your help Chas54 :D (aka Corolla guru)
Evo
You need some HID mate =)
Let me know if you need any. I beat any price
NO HE DOES NOT!!
He had HID's in it for a while and they blinded everyone.
IMO HID's are great, but you really need projectors for them.
NO HE DOES NOT!!
hahahahaah
he does need HID's but he needs the right bloody housings for them. Don't get him to put them back in, it took us Brisbane crew months to get him to take it out. But it wasn't even us, it was the motorists who flashed him, swore at him and gave him the finger which convinced him the lights were too bloody blinding.
NO HE DOES NOT!!
:lol: at this!
I have seen the advantages and disadvantages of HID's and mine were probably the brightest ever, so i decided to remove them.
i liked it silver better mate sorry, nothing else is red
nice external gate too
Thanks mate, trying to get a colour scheme going, RED on the outside, blue for interior.
The gate is my bypass valve, so different to letting air out.
hahahahaah
As above, lol :P
Evo
      Aurion tyres
      Just joined
    4. 2
      2016 Hilux SR5 Coolant Issues
    5. 2
    6. 2
      ZRE182 Nudge bar
    10. 2
