Dutchie's 09 ZRE Levin ZR
dutchie101
  • Replies 250
  • Created
  • Last Reply
Top Posters In This Topic
Few new shots with Garax 6000k HID replacement globes:
and a closeup of my DIY illuminated emblem:
Hey Dutchie
Your ride looks better and better each time I look at it, Just wondering how you finished the LED emblem, I was waiting for you to finish loading the rest of the instructions on how to wire it up,
Thanks ahead
not a fan of hids, but love the backlight badge, great touch
Big fan of this car, looking stellar, where is ASRice, get your pen and paper out mate and take notes
hey do all zre's come with the rear mirrors attached like that or are they aftermarket?
whitestivo
Thanks Fellas, :D
If i get time tonight ill finish the write up or compile it in the one post. Ive actually come up with a few ways to finish it off... probably easier than what i did to start with.
WhiteStivo, do you mean the rear vision or side mirrors?
whitestivo
hurr hurr
Bit quiet here isn't it? :ph34r: Iam sure the ZRE King has some new mods to show?
Pete do you have any rolling shots of your car,or close up pics of your final ride height? curious too see 18"s and how they sit under there.. :)
Heya Peoples, man ive been flat out the last few days, crazy stylie!
Peter, One new part arrived yesterday :spiteful: Another today but Im waiting on more parts to arrive so can make up what i wanted all at once.
John, Will try to get some more shots soon for you.
Oh, and waiting on a stupid AU120 switch to control all this madness!! :blink: ;)
Ok, i bailed on work this arvo to get some work done on the ZRE, Garax Squid ring projector foggies installed!
Might try to get out tonight and get some night shots. Not quite as bright during the day as i had hoped, but im sure they will beam at night :D
Adjusting the projectors will prove to be a difficult job. With minimal light, under the front of a slammed car while trying to get to the adjustment screw... not on ramps or stands? Hmmmm how the hell do i do that??
Ah, also added the chrome strip to the front grill to see if i like it... not sure yet.
HA! Mr Peter, soo many of my asian contacts call me that! :lol:
Some night shots of the elusive squid rings...
^ with grill and projectors on
Man for some reason my down-scaling of pics is turning nice shots into visual turd :(
Charlie, Easy direct fit - same as OEM, i would say the Prius and ZRE share the exact same part number for the fogs. I wired mine to the parkers for now, once i get my fandangled switch ill hook them up independently. Easy to fit, but adjusting the projectors may be a bit of a task. I also extended my parker wires to make it easier to remove and insert them, so just run some more wire off the extension to the rings.
Cut off line as installed (not too bad really) although i suspect the Injen podfilter may actually be pushing against the garax changing the angle...its a tight fit in there and i might even lift the pod up a bit.
normal night time shot
Pete, those two words have more than enough descriptive power!
      Aurion tyres
      Just joined
    4. 2
      2016 Hilux SR5 Coolant Issues
    5. 2
    6. 2
      ZRE182 Nudge bar
    10. 2
