Tein Coil Springs
ninjaking777
Can anybody give me a heads-up on where I can get Tein S-Tech lowering springs for my 1ZZFE Corolla hatch?
Anywhere in Australia is good.
Prefer WA though.
But yeah...just dont know where to get em though
There's this fella that runs an ebay shop and he's pinned on the part thread. but try add him to msn and he'll set you up.
sale@qjp.jp
p.s. normally if u ask him to deal directly outside of ebay via bank DD its cheaper
how much these springs worth?
how much they lower by?
check out my car on Sat night ;)
there is a issue with these springs that the lowest coil on the rears does not fit completely around the retaining support so they do not actually sit on the seat properly, but if you line them up correctly when you have them installed, once you have gone over a couple of bumps they will drop into place. At present one of my rears is seated properly and the other is out of alignment so has not lowered that side as dramatically, but the drop is good, but not certain of the actual figure. If you check the tein website it has all the specs there...
