Supercharge or turbocharge VVTL-i
Consider the hidden cost to fix minor annoying issues. -
Centre Bearing Replacement
Hey, Ive installed a new centre bearing on my 2000 model 2.7ltr Hilux. I replaced it due to a shuttering feeling coming from the drive shaft. After I replaced it I could smell the rubber burning and the shutter came back. Looked at the bearing and it has way too much play in it. Any suggestions would be greatly appreciated. Cheers -
Hey gang, i have a 2013 kluger grande and am looking to upgrade the firmware/software to the media player for radio and GPS. Can domeone point me in the direction as where to download it ans install without going to Toyota dealer? Thank you -
6
I have run into same issue as previous post. Limited replacement choice for 245/60R18's on a stock 2019 GXL Kluger. Does anyone know if you can fit 255 on the stock rim instead. There is a much better choice in that tyre size. I have mailed a couple of Tyre places as well but no reply which makes me think that it is not legal. -
hi l have a 2003 TOyota camry thats done 300,000km, l noticed sometimes but not often when l turn the steering wheel a hear a slight single squeak noise, maybe it happens once every second time l drive . l am getting it serviced in a couple of weeks to l will get it checked then, but what do you think is causing it, do you think its most likely a minor problem or could it be serious -
.I have 2006 very last 100 landcruiser Sahara. Mine brakes on front left and right going round corners for no reason. Not sliding replaced sensors/ front diff/ all new hydraulic shockers/ new abs system .Nothing shows up on computer when checked..Spent to $15000 and it still does it. Any one in Melbourne can fix it? -
4
Front Cameras
Can Camera's with Sensors be retrofitted in place of the sensors? -
51
Not ideal where you are but I would ry a couple of things: Either disconnect the batteries (both) and leave for a good 10 mins - enough time for all electrics to discharge.. Another one which worked for me was to disconnect the ECU - big plug on the passenger side firewall. Same thing, allow for electrics/electronics to discharge. Not practical for you at this stage but if you can get a Scangauge. This will allow you to clear the codes. Car has gone in limp mode. I had this problem several times whilst towing a caravan due to a performance chip which would cause a limp mode. No more as I have had the ECU remapped.
