Aurion Wheels / Rims / Tyres / Tires Specification Thread
DJKOR
If u dont mind, could someone please explain to me the safety risk involved here? or link me to where it was explained and also what the middle number before the 'R' means. Thanks!
235/45/20
235 refers to the width, 45 refers to the Aspect ratio, and 20 for the rim size. http://www.carbonbla...nformation.aspx
Messing with the wheels in changing the rim size and tyre profile will mess with the speedo reading. It'll inaccurately point somewhere where in fact you might be actually going slower / faster hence safety and obvious financial problems, like speeding..
Not only that, if you mess with your rolling diameter to the point that it is a fair bit of a change (3% is usually the maximum change recommended), if this is in the negative direction (smaller) then that means that for a given speed, your wheels will be rotating faster. Your brakes will then be working harder as a result.
Thanks, That link is helpful!
Hi All,
It has been a while since i've posted somthing so hope this helps as most of the time I need the help..lol
My Set up:
19" Lenso Type M ( Black with Red Lip )
Sitting on Kuhmo CCST Sports 235/35R19 - VERY NOISY TYRE
Lowered Using Pedders Sport Ryders Dropped 2" all round
NO RUBBING but sometimes too low for peoples drive ways.
Im Looking at putting the stock Sportivo Rims back on.....Do want to sell my Lenzo's if anyone is interested or will swap for stock with added money
Can contact me on 0431144069.
My setup
Wheels - Zumbo Kuverup 20" x 8.5 +38 offset, 225/30/20 tyres
Suspension - Pedders Sports Ryder springs, ride comfort and handling has improved over stock which was a big suprise, no rubbing at all, could be a bit more lower but i guess the springs need abit of time to settle.
No issues so far.............
post-21118-128705360313_thumb.jpg post-21118-128705366372_thumb.jpg post-21118-128705370067_thumb.jpg
Edited by ddr11
Wheel Brand: LWT EQUUS
Wheel Size: 19"
Wheel Width: 8"
Wheel Offset: +38
Tyre Size: 245/35/R19 PDW Altenzo
Tyre Pressures: 40psi
Suspension Type: Pedders Extreme XA Coilovers (set up mainly for comfort)/Ultra Racing strut brace & Ultra Racing rear sway bar
Feedback: Very happy so far, tires a bit noiser than my previous RE001, but still bearable. will upgrade tires to RE050A once these wear out...
Wheel Brand/Design: Advanti Gauntlet
Wheel size: 19Inch
Wheel width: 8.5
Wheel offset: +45 If I'm not Mistaken
Tire size: 245/35 ZR19 93Y Falken FK452 Directional
Suspension type: Standard Sportivo Chassis bracing, TRD Aurion Shock Absorbers, TRD Springs from the US of A. Ultra Racing 19mm roll bar and Strut Tower Brace, Peddars front/Rear Camber bolts.
Feedback: Turns in sharply, corners flat and allows you too use a few more of those killer wasps more often. FK452's have tonnes of grip in both the wet and dry a little noisy for the first few thousands kays but soons settles down after that.
Now how many ppl running 20" and even 19" have the right load rated tyres :P that's another thing that should of been asked..
crap?? i'd like to think that everybody is running atleast "93" speed rated tyres? otherwise your basically screwed????
  • 6 months later...
Wheel Brand/Design: Vertini Savari
Wheel size: 18"
Wheel width: 8 inch
Wheel offset: +35 mm
Tire size: 235/40/R18
Suspension type: Stock at-x, will lower for better look later...
post-19140-0-27033800-1307429719_thumb.j
post-19140-0-69339600-1307429726_thumb.j
post-19140-0-02232700-1307429732_thumb.j
Edited by jaysonn341
  • 7 months later...
post-20658-128530869685_thumb.jpgpost-20658-128530871586_thumb.jpgpost-20658-128530873518_thumb.jpg
Wheel Brand/Design: XHP
Wheel size: 20 inch
Wheel width: 8.5
Wheel offset: <eg. +45, +35 mm etc> Unsure at this stage
Tyre size: Front and Rear indentical 235/35/R20
Tyre Brand : Nankang Ultra Sport (very noisey, Increased cabin noise by about 50%)
Suspension type: Standard SX6 09 Upgrade
Feedback: Only fitted them on Tuesday , No problems as yet
Bought Them From Bob Jane Bankstown
Also looking around for 09 upgrade SX6 wheels and Tyres, The ones i traded in were sold a bit 2 quick .
May be bringing up old issues, but just curious as to how your wheels have performed?
I'm assuming you had no problems fitting 20" to the sportivo? No rubbing etc? Did you have to mod anything to fit the rims?
There are many guys here running on 20s. Most of them have no problem, dpending on the tire size, offset of your wheels, and how low you low your car. Some who are running lower offset / wider wheels have their guards rolled. Other than that, they live with their scrubs.
i got my 20inch rim 8.5 45 offset 245-35-20 on kumho ku19 with kingsprings it seats in a perfect height even with full loads. but the only thing it increase alots weight to the steering wheel it heaver then my 18 inch rims you can see them in my pictures
So I've got a novice question I'm afraid - will ford tyres fit 2009 Aurion?? I seem to see some adverts stating fit ford, honda accord, toyota ???? :wacko:
Tyres or wheels?
  • 1 year later...
Sorry wheels. I have been trying to source (yes should probably just measure) the stud pattern details for aurion - not that easy to simply locate.
...Thanks Vick
Just had mine fitted. Stud pattern is 5x114.3, same as Camry's etc.
Size 20"
Wheel Width 8.5
Suspension Stock TRD
Tyre 225/35/20: The place I got my wheels told me if I go 20's I'll need to go 225s otherwise it'll scrub at the back. Anyone running 245/35/20 with stock or lowered suspension and no dramas with it?
Wheel Brand/Design: ANZ Revolution in chrome
Wheel size: 18"
Wheel width: 8"
Wheel offset: +45mm
Tire size: 225/45/18
Suspension type: Stock Prodigy springs, soon to be King
Feedback: Standard size/spec for Toyota Aurion Kappa wheels, good ride, no change in speedometer.
Wheel Brand/Design: Advan Racing RG-D
Wheel size: 19"
Wheel width: 8.5" & 9.5"
Wheel offset: +25mm
Tire size: 225/35/19 & 235/35/19
Suspension type: BC BR Coilovers
Feedback: Scrubbed heaps on the king springs, put in the BCs and with rolling, flaring and praying only scrubs on large bumps.
FIRST SETUP
Wheel Brand/Design: forgot
Wheel size: 19"
Wheel width: 8.5"
Wheel offset: +38mm
Tire size: 245 / 35 / 19
Suspension type: King Springs
Feedback: no problems at all
___________________________________________________________________________
SECOND SETUP
Wheel Brand/Design: bbs lm
Wheel size: 18"
Wheel width: 9" & 10"
Wheel offset: +35mm & +20mm
Tire size: 245 / 40 / 18
Suspension type: BC BR Coilovers with rear camber bolts
Feedback: depends how low you go , had to pump the rear guards, and now it sits near the side wall, scrubs on turn or with full load
Wheel Brand: Lenso Como. Hyper Black
Wheel Size: 20"
Wheel Width: 8.5"
Wheel Offset: +43mm
Tyre Size: 245/35/R20 Kumho KU31
Tyre Pressures: 40psi allround
Suspension Type: Stock Sportivo
Feedback: Only got them today, however drove home on them from the Gold Coast to Brisbane. So far so good. No scrubbing around tight corners on my street. Slightly noisier tyres than the stock Michelin tyres but not by much at all. Negligible change in speedo reading (1% or thereabouts). Very happy with them so far, hopefully there's no problems in the future
post-26156-0-98518600-1375516651_thumb.j
Wheel brand: Stance sc-6ix
Wheel size: 19inch
Wheel width: 8.5inch
Offset: +28mm allround
Tyre pressure: 38psi (not sure if this is suitable)
Suspension: BC BR Coilovers withe 250mm extender for rears (approx 50mm poke between rear seat and shelf)
General: Car lowered, no scrubbing so far (only three people tried in car), no rolling or pumping of guards, front looks quite flush, rear could do with a spacer
Wheel Brand/Design: Avant Garde M550
Wheel size: 19
Wheel width: 9.5
Wheel offset: +42
Tire size: 235/35 R19 PDW Altenzo's 93W
Suspension type: BC Racing Coilovers 8kg F 4.5kg R, UR strut bar & rsb, Will adjust front camber -1.5 to -2
Feedback: Scrubs with full load and hard bumps, High road noise with tyres
https://scontent-a-sin.xx.fbcdn.net/hphotos-ash2/t31.0-8/812585_10200855618926937_343770132_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xpa1/t31.0-8/1097081_10200855619246945_746164655_o.jpg
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-xfa1/t31.0-8/1149552_10200855619526952_1259846401_o.jpg
Edited by whitezr6
Hi guys. I'm looking at swapping my stock 16" wheels for a set of 18"s from a Territory.
Would someone be able to rattle off what the 18" wheel specs for the Aurions? I'm hoping they're not too far from the Territory specs.
I believe the territory is 7.5" in width.
