![jeffy](http://toyotaownersau.b-cdn.net/uploads/monthly_2018_06/IMG-20170707-WA0019.thumb.jpg.27f6dea937638b6dcc39e001fb405530.jpg)
By
jeffy
in Members Rides
Lowering Aurion GSV50R
Hi guys First post for me also. I was just reading the email to Sam regarding lowering the GSV50R series and im glad to hear that there are lowered springs to fit the 50 series. As you have recommended Kings and Pedders, i am just struggling to find them to order online as it says that the product is not available. If you can send us a link for me to order these springs for my 2012 Sportivo ZR6 that would be great 🙂 thank you Mo -
5
Drivers side mirrors - zze122 vs zre122
THE BACKS ON MOST TOYOTA MIRRORS JUST CLIP ON SO YOU CAN SWAP THEM. INCREASED OIL CONSUPTION IS NORMAL FOR OLDER ENGINES. YOU CAN BUY OIL DESIGNED FOR HIGH MILAGE ENGINES, THAT WILL SLOW DOWN THE USEAGE, 1ZZ ENGINES USE OIL AFTER A WHILE, BUT IT IS NOT WORTH REPAIRING, IF YOU WANT TO KEEP THE CAR YOU WOULD BE BEST OFF SOURCING A NEWER ENGINE FROM A WRECKER OR ENGINE IMPORTER.- 1
5
Brake issues with 2024 Corolla Cross Hybrid
@otnimus did you ever get to the bottom of this issue? Was it the "hybrid" brake pedal causing it ? -
Hi All, A roo took out my driver's side mirror yesterday and I need to replace it. I've got an 03 ascent wagon - zze122. I've found a mirror online, but it's zre122. Do you know if this matters for the mirror? I can't find info about it online. And, I've got painted backs to my mirrors, but the one I've found is black. I went back and retrieved the parts off the road and the painted back doesn't have any damage to the connections. Is it likely that the black back on the new mirror will just pop off in the same way so I can put my original back on? Thank you Great car btw - it's for 310,000km on the clock and has only just started drinking oil, in the last 20,000km. The only off service problems I've had on it have been the headlight lever ($120 to replace) and the rear passenger door auto lock sporadically didn't work (swapped it out with one from a wrecked car I got for free and its going strong). Oh, and had a coin put in the cigarette lighter then my stereo stopped working - replaced the fuse and good as new. Any idea how long it'll keep on going? -
Highest and lowest diff ratio
Hi anyone know 2016 workmate petrol manual, the rear diff ratio. ??? -
RAV4
Hi, a new owner of a 2004 RAV4. 5 door manual cruiser. Just trying to get my head around a few things. A. Meaning of aca23r B. I think I have a Series 2. Are some parts interchangeable, dash aircon vents, front bumper.sun visors. Rear tail gate door. Not very mechanically minded. Any help would be greatly appreciated. Thanks. Pete. -
Ute Tub Swap
Hey everyone. I currently have a 2020 Hilux sr and looking to swap 2022 Rogue tub over. My question is will it fit and or work? -
Putting a R151F in my 1998 ln167r IFS
I have seen a few video and bits and pieces of information floating around and just was a definitive yes or no. If yes, what kind of work/parts are needed.
