How to make windscreen fluid?
czaja74
I buy concentrated washer fluid from Repco. Recommended is 30ml per 1L on the bottle i use but i found that a bit weak.
I use a 2.4l fruit juice bottle to work out how much i pour in. I pour the blue concentrated washer fluid to the top of the pointy section at the bottom of the bottle and then top it up with water.
Just buy a bottle of cheap pH Neutral shampoo, and mix 1 part shampoo in 5 parts warm water. Shake a bit to fully mix then fill windscreen washer reservoir.
Alternatively, give a good 1 second squirt of shampoo into reservoir when it's empty, or up to 1/2 full, then top it up with water. It'll get mixed up nicely when you drive because of the twists and turns and bumps on the road.
Works for me, plus there's also the nice smell the shampoo leaves behind too. :D
VERY IMPORTANT : Make sure it's pH NEUTRAL shampoo. Acidic or alkaline shampoo will cause your windscreen wiper rubbers to perish prematurely. Use cheap shampoo, but NOT cheap AND NASTY.
Edited by Beep Beep
i use the "morning fresh" dishwashing liquid :3
a drop or two in a 2L Coke bottle, warm water (to dissolve quicker),
and viola, :D !
I would highly recommend not using dishwashing liquid has it is much more abrasive than normal washer fluid. Your paint will not like it.
and viola, :D !
:g: i see.. can i use beeps shampoo method then ?
My patented method to filling up the wiper fluid
1) Connect garden hose to tap
2) Insert nozzle of hose into reservoir
3) Turn tap on
4) Turn tap off when reservoir is full
3) Turn tap on
:clap:
heheheh :P
Why not just buy the ArmorAll windscreen wash. It is good for 5 reservoirs and costs less than a $10 bill
Yea I use that. Not too expensive and does a good job. Doesn't leave stains.
3) Turn tap on
:clap:
heheheh :P
Hahahaha yep exactly what i do, becaus i never use the washers... it scratches the windscreen... wash it properly with soap water and a sponge
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    4. 199
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    9. 11
      300 series turbo issues
