October Meet - 31st October 2010
Help with Head unit Upgrade ?
Hello there, I have just purchased my first car, a used 2013 Corolla ZR Levin, wonderful machine !!!!!!! But the entertainment unit is a bit dated (see photos), i was interested in upgrading to something with Android auto (probably DIY). But i have no clue how to go about finding the perfect system that'll fit in the dash. Also, if there could be a USB-C connection that could be cleanly mounted into the blank spot next to the heated seat controls to run the unit directly from phone, is that at all possible? Can someone please provide some ideas as to how i might get this done, or if it is even possible............... Thanks fellas- corolla levin zr
- head unit
(and 1 more)
Tagged with:
8
update Peter Kittle diagnosed it as a Transaxle noise and they submitted an out of warranty claim. Toyota Aust honored the claim and replaced the transmission(transaxle assembly). My diagnostic fee was also refunded. Thankyou Liam at Peter Kittle for listening and responding to the issue. -
Just had new alternator installed and reverse camera has los
Just had new alternator installed on 2010 Aurion but have now lost colour on reverse camera -
Part Wanted for 80, 100, 105 Series Landcruiser Spring Cap
Hi, I am trying to obtain the part pictured, it is called a Spring Cap and it is spot welded to the chassis, called either a Spring Cap or Rear Spring Bumper Unit, the bump stop attaches to it and you can see it neatly inside the rear spring, this can be left or right it has no orientation, I want to buy either new or used. I have tried on some other forums and also many, many wreckers, it is hard to get at so wreckers don't really want to get involved, I was offered one in an 80 series and I could take it out myself for $20.00, Bargain, but they would not allow me to put the wreck on its side to access it and after surveying the job decided I could not do it in the position it was in, is there anyone who wither has one, knows where I can get one or has useful information to help in me finding one, I am happy to pay postage or even drive a bit of distance to remove one from a chassis I can get at? any help appreciated. I am in North Lakes Qld, 35k North of Brisbane. Graeme power -
2016 Aurion Sportivo rear speaker removal/replacement
Hello again One of the rear speakers in my aurion has begun rattling and needs to be removed/replaced. Does anyone know how to get access to the speaker to replace it and does anyone have any recommendations for replacement speakers. it is the rear left speaker under the larger cover. Thanks again -
2016 Aurion Sportivo missing electric blind button
Hello everyone, Ive just bought a 2016 Aurion Sportivo and was wondering about the electric blind/sunshade button. The car seems to have the hardware for the blind itself (I think but I could be totally wrong) but the button is just missing, with a hole in its place. Does anyone know if it would be as simple as buying a replacement button? I’m not sure what the cabling for the button looks like so I can’t guarantee that the cables are there, though I would assume they are since it seems the actual blind hardware is there? Also, does anyone know what I should do with the other missing button (lane departure switch) hole. Any help would be appreciated -
88
Aurion 'Pull Left' Issue Explained
Hello all, I've just picked up a 2006 Aurion that failed a RWC .. one of the things it's said is needed is caster bushes 'front' Reading this thread seems like it would be a good idea to upgrade at the same time. Is there a how to on changing the bushes for the keen DIYer? Much appreciated, Cheers,Tim -
They may not choose to insure you, but there's a budget/low cost insurer you could check out They'd only offer 3rd party, but maybe worth a go https://www.essentialsbyaai.com.au/ -
Rear power door
Hi Alim, just open your glove box and the button is on the side, you can't miss it. If you don't see a button then you don't have a power tail gate.
