How old r u ?
295 members have voted
Ae92 genuine low ks 70800
Is this your ad in Gumtree? 1989 TOYOTA COROLLA CS SECA 5 SP MANUAL 5D LIFTBACK, 5 seats AE92 | Cars, Vans & Utes | Gumtree Australia Pine Rivers Area - Lawnton | 1325274871 If it had been like my previous Toyota Seca SX hatchback with the 4AGE engine, twin cam 100 KW which was a pocket rocket then I may have had some nostalgic interest but always the $$$. -
BATTERY in Klugar 4 years old
This indicates that the battery is getting due for replacement. As a general rule expect 3 to 5 years for the lifetime of the battery. There are a few posts about what batteries members have selected in the past. Recommended Century battery models are NS70LX MF and NS70L MF for Toyota KLUGER. Last battery that I purchased was a SuperCharge brand truck battery model MF80D26L which will also be suitable for a Toyota KLUGER. Just happens that my other Century battery which is 5 years old is currently being recharged so considering whether I really need to get a replacement. -
Hi Jeff, Try your local brake and clutch shop. If you can take your old one with you. Herb -
I left my teenage son in the car with his door open for a few hours, so the interior lights were on. I had turned off the radio, as he had his phone. NO START. The car was brought brand NEW in 2020. Lucky husband had his car and jump start for me. Then AGAIN a month later, I left the boot open to pack for a few hours. STUCK on a Sunday. Battery DEAD My Klugar has done 30,000 Kms -
Hi Mandy I have had something similar on a Nissan, no lights and no power. Does it make any unusual noises when putting your foot down? Pinking noise, whooshing or hissing noises? I take it you have had a code reader plugged in? Wondering if the MAF sensor is reading air intake incorrectly, giving this a clean with isopropyl would be beneficial anyway, but these usually these throw a light and go in to limp mode. You LC has not gone in to limp mode? can you build up speed with it? Also have you checked the car when the iginition is on that the CEL light actually works? -
‘97 Petrol 6 cyl ‘80 Series knocking/rattle below
Hi, Ive just joined, so Hello! I have had a knocking/rattle sound for a couple of months, sounds like a loose panel/body moving on chassis. Mechanic checked all this and i was told it is a loose baffle in fuel tank. Still makes noise when main tank is half full. Has anyone else had or heard of this issue please? Of course I’ll get another mechanics opinion before any major decisions, but my research shows so far that i have a BIG, expensive problem getting it fixed/replaced. Has anybody else dealt with this particular problem please? -
1989 Hilux Low Voltage
I,m pretty sure they run an external voltage regulator, mounted on the side in the engine bay, its been a while now so I'm not sure if the original had points inside which pit, stick and so on. Get yourself a fully sealed electronic one from the wreckers, as chances are someone has updated to cure symptoms like you are having, even one from another Toyota model eg Corona, will do, If yours is the original it will have a big black top on it, No more problems This is what you need; Buy Jaylec Voltage Reg 12V Denso Ext 026000-4050/4051/4070 For Toyota In589 15-867 Online | Rolan Australia -
Does anyone know where to get a kit or master cylinder for a 2005 Spyder? Regards Jeff
