Are there any Aurion Touring drivers out there?
1996 Toyota 4Runner deluxe Engine swap
Hey all, I have a 1996 4runner deluxe edition (2.8L 3L I4, 5 speed Manual - Diesel), that the gearbox is screwed... wondering if anyone would have an idea of what could fit in it Thanks Anyone who responds -
12
Hi guys,I have 2 solutions to this problem, Me : I have an early 2015 VDJ200 and I got the "Fuel system error" come up on the dash, my fix was, 1. Checked the relay for the Jet Pump in the main tank, found that the relay was not getting the earth signal from the ECU (for whatever reason). This stops the subtank from emptying into the main tank. I earthed out the relay and now the Jet pump runs as soon as you start the engine, 3yrs later and still going strong, no fault codes, all that is different is that you can hear the pump run when turning on the ignition. 2. Second possible cause (as written up in the now defunct lcool.org) The wiring on top off the fuel pump lid (connector) can melt and cause a high resistance thus stopping the pump from operating and therefore causing the subtank not emptying into the main tank. I hope this helps everyone who has this fault. Please note this applies ONLY to the Turbo Diesel V8 Cheers, Paul -
Hi We have 2014 Prado 150 series diesel which has done 304K kms. Serviced regularly. Timing belt done at 300K. Wanting to give to relative but don’t want issues for her. Is that number if kms going to be an issue. Or do you know of anything else which could be. Dianne TCB -
Most likely culprit would be an intermittant Suction Control Valve on the HP Pump. I also wouldnt rule out some FOD in the Tank...Like a piece of plastic floating around in the tank and blocking the pick up -
Bailey's Injector group..They DLC more than just the shaft like the stock Denso injectors. Run a 2 or 5 Micron Secondary Fuel Filter. This will make the Injectors last well over 400K if you change both the Filters regularly. Be very very careful when reading + injector values.. More times than not the ECU is compensating for a lazy Pot If the Engine has no EGR delete then the Intake will need cleaning, and normally it's Pot 4 that suffer first due to a less than tuned intake and the preferred intake airflow path -
1VD - Ticking Noise
Cracked Rocker..Its been known to happen. Inspect the Roller Rocker arms. This Valve Train has a roller rocker Hyd. lash adjusters..If it ticks then it's either a cracked rocker arm or less likely a buggered seal in the lash adjuster -
More likely the dealer has not cleared the Maintenance when done. I assume you have already had at least 1 service? -
5
This is a Genuine Pump. I have purchased one of them and they are the real deal..Only $204 https://www.ebay.com.au/itm/193423510411?itmmeta=01HZKTGWM45A0T8344CT9FDJE1&hash=item2d08f08b8b:g:kl8AAOSwNIdjvhes&itmprp=enc%3AAQAJAAAA0HhqVFSyBnU7PEsPNMQZxkkyoA4eM0GttJtcLihIarD%2BAFiXMRernfQR9%2FxzyNVxz%2BxslUSxn3pvysuEuiUGoQBoIkEy4xO0mEsSBj4i8yJ%2F3ah3SOn2PoXoE5dvE0Q386%2BK5GC7fw4Mlvxb1iCYrRCBvoOhOZZkpp%2BsRIZ4KWxGNHWaevcjlwEjgmPEHPqxNnJuxlfj6GYyh9N%2B7o%2BBZC7eIP%2BpOfuuIkwjEPi7vVI3woVVQ6uqQUq0uOXQxKopQ%2BaZlbuYuAKvnVbwDjd8oso%3D|tkp%3ABk9SR6jKw_r8Yw -
Nice Car. Is it still forsale? -
Ae92 genuine low ks 70800
Is this your ad in Gumtree? 1989 TOYOTA COROLLA CS SECA 5 SP MANUAL 5D LIFTBACK, 5 seats AE92 | Cars, Vans & Utes | Gumtree Australia Pine Rivers Area - Lawnton | 1325274871 If it had been like my previous Toyota Seca SX hatchback with the 4AGE engine, twin cam 100 KW which was a pocket rocket then I may have had some nostalgic interest but always the $$$.
