How old r u ?
295 members have voted
FUEL WARNING MESSAGE
Glad you got it sorted Geoff. I think I got a win on mine too. I ended up replacing the entire unit inside the fuel tank. The pump was working but was very sick sounding. Also, the filter was very dirty too. I supposed it's to be expected after 14 years. What I can say is that I think some fuel was being pumped from the rear tank, but I think between the filter and the sick pump, it was not enough to empty the rear tank could empty quick enough. Maybe replacing the filter could have gotten me over the line, but I didn't want to have to do the job again. Perhaps if I was selling the car, I might have a different opinion. Its half a day that I won't forget anytime soon. I think I ended up with more diesel on me than on the ground.... -
Consider the hidden cost to fix minor annoying issues. -
Centre Bearing Replacement
Hey, Ive installed a new centre bearing on my 2000 model 2.7ltr Hilux. I replaced it due to a shuttering feeling coming from the drive shaft. After I replaced it I could smell the rubber burning and the shutter came back. Looked at the bearing and it has way too much play in it. Any suggestions would be greatly appreciated. Cheers -
Hey gang, i have a 2013 kluger grande and am looking to upgrade the firmware/software to the media player for radio and GPS. Can domeone point me in the direction as where to download it ans install without going to Toyota dealer? Thank you -
6
I have run into same issue as previous post. Limited replacement choice for 245/60R18's on a stock 2019 GXL Kluger. Does anyone know if you can fit 255 on the stock rim instead. There is a much better choice in that tyre size. I have mailed a couple of Tyre places as well but no reply which makes me think that it is not legal. -
hi l have a 2003 TOyota camry thats done 300,000km, l noticed sometimes but not often when l turn the steering wheel a hear a slight single squeak noise, maybe it happens once every second time l drive . l am getting it serviced in a couple of weeks to l will get it checked then, but what do you think is causing it, do you think its most likely a minor problem or could it be serious -
.I have 2006 very last 100 landcruiser Sahara. Mine brakes on front left and right going round corners for no reason. Not sliding replaced sensors/ front diff/ all new hydraulic shockers/ new abs system .Nothing shows up on computer when checked..Spent to $15000 and it still does it. Any one in Melbourne can fix it? -
4
Front Cameras
Can Camera's with Sensors be retrofitted in place of the sensors?
