Thread Removed.
[Post Removed]
32 members have voted
overheated engine
62
Tyre Sale Specials
- tyre specials
(and 1 more)
Tagged with:
10
Remote start
It's possible that it could be something fouling or dirt build up, dry, or a broken mechanism, so have a look and give the mechanism some lubrication, most likely though, it'll be the actuator. I found one for a good price on Ebay, $25 delivered: Front Door Lock Actuator Right Side For Toyota Camry 1997-2001 | eBay
