Aurion vs XR6
2006 Aurion 222000kms
Bought this in 2008 and has a full service history since then. Blue, touring mag wheels, cloth seats, new tyres (yokohama) recently, brakes replaced, aircon compressor replaced (12 months back) It has a couple of small dents (bonnet and boot spoiler) but the car runs very well. Located Wodonga until Sunday then in Croydon Vic from December. Registered, no RWC. $3500 -
Tyre Sale Specials
- tyre specials
(and 1 more)
Tagged with:
overheated engine
62
Tyre Sale Specials
- tyre specials
(and 1 more)
Tagged with:
10
OK. Does any of Toyota's advertising material mention Android Auto? If so then kick up a stink, with Toyota management, about misrepresentation and false advertising, reminding them of the hefty fines. Herb
