spark plug replacement
SCOOTA44
I have been thinking long and hard as to why are people removing the Manifold, Air filter housing, throttle body, Vacume hose??
Seriously, if you bothered to read, a number of people here have already changed the plugs without removing the manifold . You have not discovered America.
  • 9 months later...
Just purchased the Autolites XP5325 from Sparkplugs.com. $6.69 each.
We'll see when it arrives, really the shipping cost is only worth it when buying in bulk.
Fortunately I needed extra plugs for (IK31 @ $16 *Hiaks*) my other car so ordered that lot.
Here another brand to choose: Autolite APP5325 double Platinum spark plug
Here the catalogue: http://www.noelsauto...20Car%20Cat.pdf you will see it has Toyota Aurion 3.5V6.
Here you can purchase from Amazon.com: http://www.amazon.co...ASIN=B000PAM77O $3.86
Any feedback on these Autolite spark plugs?
I have just changed the spark plugs, and first thing that comes to mind is why on earth did DJKOR suggest to remove the Manifold, Air filter housing, throttle body, Vacuum hose replace gasket If anyone has one in stock! ??
I can understand from a point of view more room, but buying or waiting for the exhaust manifold gasket takes time and cost money. and there is a much simpler way of doing it.
Listen up....
I Removed the wind shield wiper cowl, unbolted and removed the windshield wipers, remove windshield wiper motor, unbolt the lower metal cowl, then unbolted the bracket that’s connected to the manifold and engine as it covers the 1st rear plug, (far left) disconnect all the clips and done!! There’s enough access the rear three cylinders, without any drama (and I'm not skinny or captain elastic too!!!) the last plug on the right is tricky just unbolt the wiring brackets then shift the wiring up and slide the ignition coil out. Use a stool to stand on, or remove bonnet. FAQ needs to be updated!
About a 20 - 30 minute job.
Why on earth did you suggest to remove the bonnet.
  • 9 months later...
I wouldn't mind just putting my 2 cents in here.
As a mechanic, ive done spark plugs on quite a few aurions. There's no need to remove the manifold on the aurion t get to the rear spark plugs. Only the windscreen plenum and windscreen wiper assembly, demonstrated in steps earlier in this thread
From here, you can reach behing the manifild to get to the rear plugs (and you have to remove a bracket covering the most RH coil pack)
  • 1 year later...
Prices are high aye.
I tried getting trade prices juat about every where and nothing under $20 from any stores.
So i asked my parts counter to quote me some AC Delco plugs and got some dual platinum plugs for $5.50 each.
It was worth a try so i nstaled them last week and the car feels and drives great.
Anyone who is looking for cheap Denso spark plugs, there's a set available in Melbourne for $124.50
http://www.ebay.com.au/itm/Denso-FK20HR-11-FK20HR11-Spark-Plugs-NGK-DILFR6D11-Toyota-Lexus-V6-/151550861247?pt=AU_Car_Parts_Accessories&hash=item2349229fbf
1 Set only.
OK Hi everyone,
Been busy make this for everyone who want to know the best replacement Spark Plugs to get, I've base the first 8 choices on,
1./ Total Rating
2./ Meets OE Requirements
3./ Cost
4./ Delivery
Probably can add to "The TOCAU Aurion FAQ"
https://drive.google.com/file/d/0B0JOiLVIoLJ6eDhhZl9uclI3dUk/view
  • 7 months later...
  • 2 months later...
Thanks cranky.
Denso better than Champion Denso d'ya think? They're around the same price.
http://www.ebay.com.au/itm/361231499929?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Edited by boxerboy
Hi Everyone.
Just becauses with buying off Ebay, as there are seller who are selling bodgy spark plugs, especially the Denso FK20HR11.
Why because if you can see in the picture you will notice the tip missing under the electrode u end? http://www.ebay.com.au/itm/Set-of-6-Pcs-90919-01247-Iridium-Spark-Plug-For-Toyota-Lexus-V6-3-5L-FK20HR11/281921146784?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140117125611%26meid%3D5c8f985f6f4f45da821121f7303b193d%26pid%3D100009%26rk%3D4%26rkt%3D10%26sd%3D182017838264
These are faulty plugs been sold on the black market.
  • 2 years later...
I used the above approach rather than remove the intake and replace gaskets. Started at 4:30pm and paused at 7:30pm after replacing the spark plugs and ignition coils for the rear bank then reassembling. Probably could have saved 30 minutes by being better organized and having to find better quality 6 point socket and breaker bar to undo 2 of the nuts on the passenger side strut mount. Surprisingly, driver's side strut mount nuts came undone quite readily. Only took 20-30 minutes to replace the spark plugs and ignition coils for the front bank.
  • 2 years later...
I was thinking that it was sooner than 2 years and 4 months since I replaced both spark plugs and coils.
Just viewed this recent video by The Car Nut and I was thinking that I did not remove the intake. I now recall that I did have some fun moving the rear wiring harness out of the way to get to the spark plugs. I am sure that I did put some anti-seize on the spark plug threads.
      New member seeking advice for parts
    2. 39
      Pics of my Kluger steering wheel removal
    3. 14
      1zz to 2zz
    4. 0
      Can I put a 2010 bumper on my 2008 Camry ?
      Anyone else tried these seat covers ?
    6. 1
      Digital Speedometer
    7. 0
      am2 fuse blowing
      Toyota Celica '96 5S-FE no spark
      Toyota Camry 2003 Driver seat recline issue
