What did you do to your car today?
Tivo Restyle.... Haters gonna hate
It’s not bad looks like a jdm model I forget the name -
Could you check part numbers for space saver in new shape?
Hi guys. I have a new shape 2024 C-HR in the UK. Over here they don’t have a spare wheel, but it is shown in the owners manual. As far as I can find out, some models in Australia have one. Could anyone be so kind as to have a look and see if there are any part numbers etc on the foam supports so I can ask my UK dealer about it. Thanks very much 🙂 -
In the middle of refurbing my 2003 Tivo.... I've never been a fan of the headlights, so thought I'd do something different to go with the Nardo Grey respray. What do you think? -
Hi, I have a 2005 Camry. The key fobs to unlock the doors stopped working. I changed the batteries but that didn't help. I tried reprogramming the fobs, no good. I was told that I should replace Keyless Entry Door Control Receiver Module. I cant find the the location of the module in my car. All of the videos on YouTube are American and do not match my car. I don't know if I am on the right track with this issue but I would like to find the location of the module in my car. I would appreciate any help with this problem. -
Hilux 2013 radio upgrade
Have you done a search? I recently found a website that had lots of different maps, for different cars and head units, available, but can't remember it now. Herb -
Aurion "wobble"
Maybe unrelated, but check how many turns are on those wheel nuts. These cars have studs that are too short for aftermarket wheels which use acorn nuts. Minimum of 8 turns for a 12mm stud is considered safe. Also check if correct size hub ring is fitted to the back of the rim -
RAV4 19" wheels on Aurion
Have ordered a set of RAV4 Edge 19x7.5" replicas in 40mm offset. Should fit very nicely on my 2011 Aurion with 235/40R19 tyres along with using the factory shank style lugs, will update this thread as things happen. Not liking the gloss black finish, so first up will be giving it a sand with some green superfine SIA pads (600-800g) then change the finish to satin black to bring out some details in the rims Hopefully end up with a finish like this... Might throw on some retro Toyota decals for the centre caps... -
Aurion "wobble"
Did U try rotating the wheels front to back? Bulging deformed tyres isn't uncommon with a 200kw front wheel drive -
Steering angle fault 2021 VX Prado
Hey guys Have had the steering angle fault come up in the dash only when coming to a complete stop. When you take off again the fault goes away until the process starts again when you are coming to a stop. Any suggestions for fault finding or is this a trip to Toyota. -
23
Best Oil viscosity for aurion
Always want to learn more from the experts and their opinions based upon their years of experience. This YouTube video appeared in my feed. Not saying that I understand any of the this except that it makes sense when you consider that oil additives wear out or break down. I did make note that timing chains are attributed as a factor for the shearing impact upon the oil additives. I am still thinking that it comes back to using a quality known brand engine oil and an appropriate oil change interval for your specific vehicle and driving conditions.
